Roller Rockers
but i did read on one forum that its suggest to buy new valve springs, because there is a valve float issue with running the 1.6's.
So anyhow, Im just looking for some cheap easy HP, and i heard that RR's are a good way to start.
Also, are the proform Self aligning 1.6's good? they were selling for like 150$, which dont seem bad at all....
and if anyone has any informative pictures, or a link to an install, that could help too!
You don't wanna skimp on these cause it's a bit of
a PITA to have to go back in and re-adjust them.
Do it right the first time! You'll thank youself.
What do you guys think about the trickflow rocker arms that have 1.5 for the exhaust and 1.6 for the intake? Does it seem worth it or is there enough reason to get all 1.6 RR's? Trending Topics
Anyhow, so im guessing self aligning are the only ones I should buy right?
I found some comp cams magnum ones on summit, part # 1418-16, then this a set that are RP1418-16 and they say Designed for use in engines equipped with factory hydraulic roller camshaft. Kit includes pushrods.
anyhow, are these good RR's? and which ones would I buy....
I figure if I can get some nice cheap RR's then I may as well try it.... the proforms seem to be the cheapest self aligning RR's out there, and even summit sells them so they cant be bad....right?
heres a link to my mini-project thread
https://ls1tech.com/forums/lt1-lt4-modifications/716789-finished.html
and what springs do you suggest?
Also,.... which springs/RR's do you suggest for a GM847 cam, which is what i may go with someday....
The reason I'm asking, I have a set of SA Proforms waiting to go in along with the 26918 springs.
