Transmission mount question
Old Jun 7, 2007 | 11:32 PM
firebirdhorn's Avatar
Default Transmission mount question
I first put in a cheap oem transmission mount in my formula firebird and only four months later, it busted. I just got through installing the energy suspension transmission mount which was about $20.00 more than the oem mount. I was wondering if any of you have experienced a problem with lining up the holes on the crossmember to support the Energy Suspension mount. I noticed that someone had a hard time with installing different mounts because the crossmember that the mount rests on had been drilled out a few times, and made the hole actually bigger. Just wondering if anyone else has had this problem.
Old Jun 8, 2007 | 06:52 AM
Razor_Blade's Avatar
I used the Energy Suspension poly mount on my 94Z. The holes lined up fine. Where did you buy it for the cost to be $20 more than a stocker? I bought my Energy Suspension piece at Autozone, and only paid $23.
Old Jun 8, 2007 | 07:23 AM
James Montigny's Avatar
Very common actually.
You can push the tranny back and make it fit, although people have told me that it messes up your pinion angle.
On my 95, I made the hole in the crossmember bigger and made it fit without a problem.
On my 93, I just pushed the tranny back until it fit.
Both cars had adjustable torque arms, the angle seemed fine before and after.
Old Jun 8, 2007 | 06:54 PM
SLawson86's Avatar
mine fit the same way, it was tight. i just ran the bolts in a few threads each and torqued them down, works fine
