Need Help Measuring Pushrods
I used a metric ruler and converted the milimeters into inches and placed the order. I measured from tip to tip and now I realized that there are 3 different ways to measure, but I really don't need to worry about that right now. If you can explain how to correctly measure the pushrod length I would really appreciate it, and then I can hopeully get my car running right.
Ok I'm done rambling, thanks in advance
I'm not saying your wrong, but I would hate to have to pull the intake since the motor is in the car and has run already, but it ran like garbage because the first set of pushrods were too long and the set that I have now are too short.
I really hope that you aren't right about having to use a solid lifter, but if you are thanks for the response
