intake manifold leak
Old Jun 8, 2007 | 04:34 PM
C5042081's Avatar
Default intake manifold leak
any one have a good link for for replacing the common intake manifold leak
i did try searching and found some ok write ups, any pointers would help too
Old Jun 8, 2007 | 04:40 PM
Ironxcross's Avatar
this is the page i used when i fixed mine:
http://www.projecttransam.com/projects2.asp
in that page they use links to this page:
http://www.geocities.com/MotorCity/Downs/4013/ol.html
both are pretty good.
I think the thing to remember here is the fix the cause of the leak, not just the leak there.
The cause is the passenger side EGR pipe, it heats up the back of the manifold where its just sealant, and the pressure causes it to blow out. I wrapped my egr pipe in header wrap and got high temperature sealant, its done the trick so far.
Old Jun 8, 2007 | 04:45 PM
SS MPSTR's Avatar
let the intake set up for at least 24 hours before firing the engine.
Old Jun 8, 2007 | 04:46 PM
95greenZ's Avatar
Just put a good even bead of silicone. I let the silicone set up for about 10 minutes before laying the intake down. Install the intake straight down do not move it around. Let it sit overnight before starting. It's not a hard job good luck.
Old Jun 8, 2007 | 05:10 PM
C5042081's Avatar
great, thanks everyone , should be a easy job
Old Jun 8, 2007 | 05:12 PM
WhyHelloOfficer's Avatar
Just be super careful and take your time and you'll be fine. I followed that writeup and it was super easy. The hardest part is letting it sit once you finish
Old Jun 8, 2007 | 05:38 PM
Ironxcross's Avatar
yeah, thats why i just took alot of time to make sure i did all the connections right and fixed a few other things, went to sleep and the next she was ready to go, haha.
Old Jun 8, 2007 | 06:29 PM
C5042081's Avatar
Ironxcross
off the subject how do you like your Bilstein HD's
i think there going to be my next upgrade
 Michael S. Palmer
Old Jun 8, 2007 | 06:40 PM
britdog's Avatar
There is a very good picture here that I found useful:
http://www.f-body.com/forum/showthread.php?p=90565
