Need Help Asap!!!!!!!!!!!!!!
Old Jun 13, 2007 | 12:22 AM
RGV SS's Avatar
Default Need Help Asap!!!!!!!!!!!!!!
My brother's 94 formula won't start.The motor cranks over, But it just won't start. It has new spark plugs, new wires, just finished installing new opti and I replaced the coil that sits in front of the driver side head. It has spark and it has fuel. When I try to turn it on it makes a humming sound coming from the coil or the black EGR circular box somewhere aroun there. Any ideas on what it could be? Ergent help please. This is my bro's DD
Old Jun 13, 2007 | 12:25 AM
buffman's Avatar
you replace the ignition module? It's the black sensor above the coil. Take it off and have autostore test it. You have proper fuel pressure?
Old Jun 13, 2007 | 12:32 AM
RGV SS's Avatar
Yeah I have proper fuel pressure, but I have not checked the ignition module. I'll try that out. thanks
Old Jun 13, 2007 | 07:21 AM
SAPPER's Avatar
The LT1 Module can't be checked. Some parts stores may have a way of "hotwiring" it to seem like it's testing it. But this is the only module that can't be tested. If it has spark, then it isn't the module.
You said it HAS spark. Did you test at a plug or coil? If you have spark at the coil and not the plug, you might have forgot or done something wrong in the Opti.
Keep us updated.
Old Jun 13, 2007 | 10:04 AM
Fastbird93's Avatar
Ignition fuses in the box checked?? Flooded possibly?? If the ignition fuse is good, try pulling the injector fuses and cranking for a few seconds to clean out the cylinders and see what happens.
Old Jun 13, 2007 | 12:07 PM
RGV SS's Avatar
I checked the spark from the plug not from the coil, but I will try this. And Fastbird93 I will try your idea. Thanks
