what turbo kit to buy??
I don't reccomend a 383 because a turbo already makes a LOT of torque, and upping the engine size that much will only make traction harder to get.
I myself have a PTK setup that I am piecing together to install this winter.
that has to be the most retared thing i have ever heard, dont go bigger displacement because you'll have to much torque, ive never heard of to much torque, or to much tire spin, that actually makes me think....hmmm
A 355 is a bit cheaper to build because there isn't as much in the way of machining, you can reuse the stock crank if you aren't going to turn stupid amounts of rpms, you can use smaller heads which are cheaper, a smaller cam which helps with spring life and be a little bit more kind to your drivetrain as well. I don't see the problem?
Of course some would argue my turbo setup which will consist of a 60-67mm turbo because you aren't going to hook more than 600rwhp anyway without a large budget or huge tires so I would personally rather have the response a smaller turbo will have.
