383Lt1 help
Old 06-16-2007, 07:09 PM
lt1mf's Avatar
Default 383Lt1 help
I have recently installed a 383 Lt1 in my Camaro.It has Scat 4340 forged steel crank,Scat 4340 h-beam rods,Speed-Pro forged flat-tops with 2 valve reliefs.The problem I am having is under hard acceleration the car smokes,I dont think it is coming out of the exhaust and Its blowing oil out of the valve cover breather tube hole and dipstick hole in block. Also car acts like it has a vacuum leak,It has a CC306 cam with1.6 roller rockers , power brakes work very little at low speeds and I am getting a MAP sensor code due to vacuum. Wondering if unadeqate breathing for crankcase cause too much pressure,has just factory pcv system no aftermarket breather.Approx comp. 11.75 to 1. Any help will be appreciated.
Old 06-16-2007, 07:13 PM
hpmotorsports's Avatar
When your car is idling and you take the oil fill cap of is there blowby coming out
Old 06-16-2007, 07:17 PM
lt1mf's Avatar
No,I have even run a crank case pressure test by drilling a hole in a oil cap and hooking up a vacuum/pressure gauge under hard acceleration only 1-2 psi.
Old 06-16-2007, 07:20 PM
Do you have your pcv hooked up,is it working
Old 06-16-2007, 07:24 PM
did you have to take the baffles out of v/c to clear your rockers and is it blowing oil out the dipstick itself or were it goes in the block
Old 06-17-2007, 07:37 AM
KOOLAID's Avatar
im replying under a different name but it leaks where dipstick tube goes into the block under hard acceleration but not out of the end the tube
Old 06-17-2007, 08:00 AM
Well that just needs to be sealed up , as far as smoking does it come out the exhaust or just under the hood
