Underdrive pulleys
Old Jun 17, 2007 | 12:55 PM
94Aquaformula's Avatar
Default Underdrive pulleys
As the title says i'am having a bit of a problem pulling the old one off. A buddie let me borrow the "the pulley puller tool" and it still doesn't want to budge. Was wondering if i need to do something else. Its on a 94 Lt1 firebird and the pulleys are from LMPerformance.com its the 34% crank and altornator pulley. Thanks Calvin
Old Jun 17, 2007 | 01:37 PM
thebufenator's Avatar
well, as long as you got the 3 bolts off, it should come off easily, mine came off by hand.
uhm, keep trying?
Old Jun 17, 2007 | 02:04 PM
i have tried to pry it off i have all four bolts off. The three in the front and the one in the middle and i put wd-40 on the pulley and still havent came off.
Old Jun 17, 2007 | 02:19 PM
litch2004's Avatar
Like thebufenator vbmenu_register("postmenu_7259257", true); prev. stated it should just come right off. You should even have to pull the center bolt out or even use the puller. I took out the three outer bolts and mine just came off with no applied pressure. I hate to tell you to try a rubber hammer but that might be your only choice. Good luck, and it shouldnt damage it because it was ment to just come off so it should need much persuation.
Old Jun 17, 2007 | 03:18 PM
95Z28Hustler's Avatar
Are the pulleys worth it, i've heard they were crap?? And would i wanna put them on my d-driver?
Old Jun 17, 2007 | 05:12 PM
projekt70chevelle's Avatar
Old Jun 17, 2007 | 05:53 PM
State69champ's Avatar
soak the **** with PB blaster and freakin get a claw typle puller and yank it off.. may have to take the fans out.. i did.
Old Jun 17, 2007 | 06:26 PM
AJ52486's Avatar
I actually used a Chrysler puller, it was a three-jaw type. You are probably trying to use a puller for a standard SBC, which it trying to remove the hub instead of the pulley.
Old Jun 17, 2007 | 06:30 PM
are they a reasonible upgrade?
Old Jun 17, 2007 | 10:50 PM
eh, they help the engine rev quicker, less wear on the ps pump, alternator, and a/c compressor, not really alot of power at all.
Old Jun 17, 2007 | 11:05 PM
fuzchunk's Avatar
not gona notice as much on a v8 but my stering got a stiffer feal. I like it just for that. on a smaller motor the diff can be much more pronounced.
Old Jun 17, 2007 | 11:49 PM
I finally got the pulley off tonight. I had to wiggle and pull at the same time. Thanks guys for helping me. Calvin
