bad o2 sensors?
Old Jun 20, 2007 | 12:55 AM
1slot/a408's Avatar
Default bad o2 sensors?
how owuld a bad o2 sensor affect performance of car?
Old Jun 20, 2007 | 01:11 AM
infinitebird's Avatar
your gas mileage will suck. Might not be any other noticeable difference though. It might run rough if it's doing something really wacky.
Old Jun 20, 2007 | 03:33 AM
97Lt1TA's Avatar
car would bogg and idle rough
Old Jun 20, 2007 | 08:29 AM
Blackbirdws6's Avatar
will def effect performance. replace with ac delco's
-Brian
Old Jun 20, 2007 | 10:03 AM
Fastbird93's Avatar
Having just seen the extreme effects a single bad O2 can have on a car I can say that the following is possible:
EXTREMELY bad gas mileage
VERY extreme vibrations and misfiring
I thought my buddy's car was running on 4 cylinders it was running so bad. New O2, good as new.
Old Jun 20, 2007 | 01:56 PM
C_Rules's Avatar
you'll get sputtering and backfiring.
Old Jun 20, 2007 | 07:17 PM
1slot/a408's Avatar
thanks guys...it really does sound like whats wrong with my car! gas is poor and sputters...now one last question....how to check if they are bad? can you tell by lookin at them?????
Old Jun 20, 2007 | 07:22 PM
C_Rules's Avatar
i knew mine was bad because of my datalogger readings.
Old Jun 27, 2007 | 07:45 PM
LT1_King's Avatar
my car is acting the same exact way. see i replaced the O2's about 4K miles ago with Bosch. i don't have any down stream just two on the Manifolds. back then i had the cat on my 94 Z. then i deleted the cat. it ran fine but then it started acting the way 1slot/a408. then it threw these codes. DTC 32, DTC 36, DTC 42. what could it be? the mechanic that i took it with said it was leading up to the PCM. could this be?
Old Jun 27, 2007 | 07:56 PM
You can either do a datalog (the value will appear to be stuck and not fluctuating enough), or you can unplug one or both of them. It will likely run better in open loop than in closed with a bad o2, so if the performance improves with them unplugged than you know that is the issue.
Old Jun 27, 2007 | 08:11 PM
LT1_King's Avatar
when is opn loop? is it when it's cold or when it's warmed up? and another question would new O2's like Denso or Delphi be as good as the AC DELCO ones?
Old Jun 27, 2007 | 08:15 PM
open loop is when it's cold. The normal behaviour is that open loop is only used for the first few minutes until the engine warms up then it switches to closed. But if you unplug the sensors it will stay in open.
delphi's are the ac delco part.
Old Jun 27, 2007 | 08:16 PM
LT1_King's Avatar
so they would work like the factory O2's?
Old Jun 27, 2007 | 08:18 PM
delphi = ac delco are the factory O2s. just a different name.
other ones do not work the same, and people usually have problems with them. stay with the oem part for o2s.
Old Jun 27, 2007 | 08:29 PM
LT1_King's Avatar
would this act like this even thought it's not throwing a code for the O2's just the stuff i mentioned earlier?
Old Jun 27, 2007 | 08:45 PM
bad o2s do not always throw a code.
Old Jun 27, 2007 | 09:27 PM
LT1_King's Avatar
i know this is gonna sound dumb but is there two EGR valves? i checked the on on the passenger side a while ago it seems to be good working properyl. does the other side have one too? or is it something else?
Formula350's Avatar
They only throw a code after a long time, for mine at least, but mines not as smart of a system IMO. Anyways you'd need a real-time scanner or data logger to see. My scanner does real time and the mV just chilled around 150 all the time. If they don't fluctuate between 100-900 (400-900 is best) then it's pretty safe to say it's bad.
