non-vented to vented opti conversion?
Old Jun 21, 2007 | 11:32 PM
  #41
litch2004's Avatar
you bought only the cap and rotor? If that is the case then it will not turn your distributor into a truely vented system. Not trying to dog on you or nothing just informing you that if this is all you bought and you distributor does not have the vacuum line hocked up to it then the one in the cap is almost useless.
Old Jun 21, 2007 | 11:34 PM
  #42
litch2004's Avatar
I just dont want people to be misled about the vented system, into thinking that just putting on the vented cap makes their system a vented system. If it is cheaper than the OEM replacement then you might as well get it. But if it isnt then it isnt doing you much good.
Old Jun 22, 2007 | 07:38 AM
  #43
Fastbird93's Avatar
Me personally, move to the vented setup because it really opens up your options for timing sets. With the non-vented opti setup, I.E. 92-94 timing cover, you're limited to two timing sets that I know of: OEM and Lunati. With the 95+ Timing Cover/Vented opti setup, you now have available to you the LT4 HD Timing set, Cloyes single and double rollers, ect. ect.
Old Jun 22, 2007 | 11:19 AM
  #44
Taubr Unit's Avatar
now if you do the deltec or LLTC set up is there still much need for the venting? Considering your only using the eye now? I know you can run a lot better timing gear but just puttin it out there............
Old Jun 23, 2007 | 11:33 PM
  #45
BRIANLT1's Avatar
I have a 92 Vette and converted to full vented set up. Do a seacrh on the web and you will find it is low buck easy deal. You do not need to swap optis or anything. GM sells the vacum line kit that has all the lines and clips. It was under $50. I am going on memory but you have to tap into cap and add a dab of silicone. Mine has been trouble free with 2 failed water pumps.
I found the info by searching vented optispark or opti? There is a web sire that deals with Vettes that lists the entire swap. Under $100 for all and it is vacum hooked up and fresh air drawn through your intake.
