noob question how do you take out
Old Jun 21, 2007 | 12:30 PM
Revelation Z28's Avatar
6 5
4 3
2 1
(opti)
Old Jun 21, 2007 | 12:32 PM
LT1MAN's Avatar
dont let us scare you away from changing your own plugs. first, it costs an arm and a leg to get a shop to do it. second, you need experience. the next time you do it, it will be easier. third, you learn new things about your car. so i say go for it, knowing that it is going to be time consuming and frustrating, but its definately doable. when its all done you will feel like you just climbed a mountain.
Old Jun 21, 2007 | 01:01 PM
That_guy's Avatar
Old Jun 21, 2007 | 01:06 PM
go under the car to change the injectors?
Old Jun 21, 2007 | 01:10 PM
Hark_Z's Avatar
Originally Posted by Revelation Z28
8 7
6 5
4 3
2 1
(opti)
Thanks I never even knew the right numbering..
Old Jun 21, 2007 | 01:13 PM
Hark_Z's Avatar
Was that video necessary? rofl
Old Jun 21, 2007 | 01:14 PM
Ralls's Avatar
That's exactly what I thought You were showing the injectors.
Old Jun 21, 2007 | 01:29 PM
That_guy's Avatar
wait wait wait lol ive been wrong about everything lol those things by the manifold are the injectors i thought they was the spark plugs WTH
BTW i was trying to point at the spark plugs not the injectors lol although it time to change those lines too but thats a later project.
Old Jun 21, 2007 | 01:47 PM
Hark_Z's Avatar
You have to remove the plug wires then spark plugs are underneath.
Old Jun 21, 2007 | 01:53 PM
LT1MAN's Avatar
thanks for the new sig quote
Old Jun 21, 2007 | 02:00 PM
383astro's Avatar
You have nearly 500 posts and dont know what the difference is between spark plugs and injectors? Im not bashing you at all but what did you learn through the 490+ posts?
Old Jun 21, 2007 | 02:15 PM
  #32
That_guy's Avatar
lol i kno a lil bit but i swear i thought the spark plugs where the 8 things by the manifold i wasnt tryin to film the fuel injectors
Old Jun 21, 2007 | 02:16 PM
  #33
That_guy's Avatar
now wait a min are we talking about the fuel injectors in kno what that is im talking about the plugs lol so what are those 8 things by the manifold the spark plugs right and ur welcome bout the sig lol
Old Jun 21, 2007 | 02:46 PM
  #34
spark plugs are underneath the exhaust manifolds
Old Jun 21, 2007 | 02:54 PM
  #35
Ralls's Avatar
It's okay not to know anything about cars. There are rich people out there that have fast *** cars but pay people to do everything. But if your on a tech website looking to replace spark plugs, of course your going to get ****.
Anyways, you say you know what injectors are but then your asking what the 8 things are on the manifold (THE INJECTORS). That's the intake manifold too, you could be referring to the exhaust manifolds so I don't know which one you mean.
This reminds me of a friend that took 30 min to jack up his car, 10 min to break a lug nut loose, and would of been hours if I didn't help him rotate his tires.
Old Jun 21, 2007 | 03:01 PM
  #36
the_merv's Avatar
Veteran: Air Force
Everyone's got to start somewhere..
Plugs are not that bad..then again that's coming from me..I take Engines out and swap them with the ones that I build, on top of all the other custom things I do with my car.
Old Jun 21, 2007 | 03:03 PM
  #37
buffman's Avatar
Why are you wanting to remove the plugs anyways? If you seafoam a car via sucking it through the intake manifold, You need to go and drive the car afterwards and beat the snot out of it. Otherwise if you do like every other person I've talked to, Letting it sit in the driveway while you revv the **** outta if, you're going to have a good chance of leaving **** all over the plugs.
You don't have to change oil after seafoam unless you run it in the crankcase, or have really worn out rings that would allow the stuff to make it past them.
Old Jun 21, 2007 | 03:13 PM
  #38
Hot94Z28's Avatar
man i want to help but you are confusing
Old Jun 21, 2007 | 03:20 PM
  #39
John95Z28's Avatar
I just finished doing my spark plugs; not much fun, but certainly doable. I had to get #7 and #8 from below. Number 2 was the worst by far, IMO. Next time I'm going to try removing the alternator first, to see how much that helps reaching #2
Old Jun 21, 2007 | 08:11 PM
  #40
That_guy's Avatar
Ok you guys can help out im sorri wait maybe these vids will explain everything i actually thought those where the spark plugs lol. im in for some work.
