Mystery of the Hovering Shifter
Old Jun 23, 2007 | 03:11 AM
RickyMartinZ28's Avatar
Default Mystery of the Hovering Shifter
My neighbor's 95' TA has a 6-speed and whenever you step on the gas very hard at all the shifter raises up about 2-3inches. It doesn't get hard to shift or anything but its kinda strange. Anyone else have this problem?
Old Jun 23, 2007 | 04:54 AM
Revelation Z28's Avatar
mine moves 1/2" to 1" when i give it gas.
new trans mount too.
Old Jun 23, 2007 | 05:51 AM
Formula350's Avatar
My guess would be motor mounts along with the normal flex of the trans mount. Run a Energy Suspension trans mount. It has metal in it that lock when it flexes too far.
Old Jun 23, 2007 | 04:49 PM
i think its just normal because my engine doesnt move at all when i rev it and look at it.
Old Jun 23, 2007 | 05:19 PM
Well its kinda strange cause it used to only move a little bit but one day this rubber peice fell out and its all mangled and now it jumps out outta the boot.
Old Jun 23, 2007 | 05:25 PM
TheBiz's Avatar
Broke the trany mount.
Ralls's Avatar
Your motor will hardly move while revving it. It's not under load.
The shifter moving around is normal. Think about it, it's directly connected to the transmission which is getting lots of stress. If it's really bad, then a new tranny mount will help.
Old Jun 23, 2007 | 05:45 PM
when i had no hood on and i drove my friend was following me and he told me my engine stays still.
Old Jun 23, 2007 | 08:57 PM
compt/aclone's Avatar
just wondering but how did your friend see your engine if he was following you.
Old Jun 23, 2007 | 09:27 PM
ORedRoc4's Avatar
lol^, But if you replace the tranny mounts/bushings with poly, it'll fix it stiff... My stick doesn't even move at all when i look at it...
-justin
Old Jun 23, 2007 | 09:40 PM
the_merv's Avatar
Veteran: Air Force
It moves up cause the Tranny Mount is gone. The reason it moves up when you gun it is cause the Torque Arm is mounted to the back of the Tranny, and the Geometry of the Suspension when you gun it causes the Torque Arm to push up, taking the Tranny with it.
Old Jun 23, 2007 | 10:05 PM
you know what i mean he was in front of me when going to the body shop.
my shifter moves up on idle when revving or under load. doesnt bother me one bit either.
Old Jun 24, 2007 | 01:06 AM
Formula350's Avatar
I still say get the Energy Polly Mount. I had one on my A4 TPI, loved it. I should've took it out before I sold the car >_< (Along with it's built tranny since mines a 700R4 too)
Old Jun 24, 2007 | 06:51 AM
the_merv's Avatar
Veteran: Air Force
I have the Energy Suspension one also, nice mount..
Old Jun 27, 2007 | 04:51 PM
TheBiz's Avatar
Ditto. The LT4 solid rubber mount will also stiffin' things up quite a bit.
Old Jun 27, 2007 | 05:05 PM
Gun5's Avatar
im looking for some new mounts not completely stiff but something that will be a step over stock what am i looking at ?
Old Jun 28, 2007 | 09:18 PM
TheBiz's Avatar
Motor or tranny? Motor, just go with the energy suspension poly ones. For the tranny, I would go with the LT4 solid rubber mount. Stiffer than stock, but doesn't transfer as much movement as the poly mounts.
Old Jun 28, 2007 | 10:29 PM
Formula350's Avatar
Again, the Poly has a limit before the metal catches. So it only gives so much. It also means it'll out last them all It's the benefit of a solid, with the 'comfort' of a rubber.
