503 cam
Old Jun 25, 2007 | 04:46 PM
cam2z's Avatar
Default 503 cam
will i need to use guideplates with this cam or can i get some self alining rockers to use i will also be using 1.6 rockers. thanks
Old Jun 25, 2007 | 06:04 PM
seawolf06's Avatar
Depends on the springs I think. Most will recommend NSA, though.
Old Jun 25, 2007 | 07:24 PM
dhdenney's Avatar
If you have to buy rockers anyway, just go ahead and get the NSA's. If you already have SA's, then don't worry about it too much.
Old Jun 25, 2007 | 08:04 PM
StealthFormula's Avatar
When getting advice and a quote for install, Harris Speed Works who is a sponsor here said NSA 1.6RR's were too overkill for my setup (CC503 cam, Crane Springs on Stock Heads) so I went with Comp Cams Magnum SA 1.6RR's just to give you an idea.
Old Jun 25, 2007 | 10:56 PM
69gto96z's Avatar
Stealth, were you running the Crane 10308 springs?
Old Jun 25, 2007 | 11:17 PM
Those are the springs I will be running in my setup next month
