Brake Swap
Old Jun 27, 2007 | 01:09 AM
Ridnkawie4life's Avatar
Default Brake Swap
alright, i was wondering about this for a while now and i have searched but found no results...but...what would have to be done in order for me to switch my lt1 brake set up to an ls1 brake set up???
Old Jun 27, 2007 | 02:18 AM
jester1614's Avatar
i am in the process right now of acquiring the parts. what you need is the front rotors calipers and spindles as far as i know.
Old Jun 27, 2007 | 02:19 AM
the_merv's Avatar
Veteran: Air Force
Switch out the complete Spindle Assembly, then bolt everything back into place.
Here is the difference in them.. and trust me there is a big difference.
Old Jun 27, 2007 | 02:27 AM
Gun5's Avatar
yep its a easy mod to hell i got the stock pads from someones 01 SS that got totalled on my car rotors where good to braking is 100% better... next thing ill do is a porp valve
Old Jun 27, 2007 | 02:29 AM
the_merv's Avatar
Veteran: Air Force
I did my version of ABS Delete, so I will see how good they go together.
Old Jun 27, 2007 | 02:35 AM
Gun5's Avatar
been waiting for u to test that **** merv so i can get one im about ready to order a SJM kit but $185 is kinda btw does that strut bar upfront really help that much pretty cheap $50 mod
Old Jun 27, 2007 | 02:43 AM
the_merv's Avatar
Veteran: Air Force
I felt a little difference..then again I am a Hardtop. I think you guys with the T-tops might feel it a little better. It's a definate improvement.
Give me a little bit to test it, mine will be on the road here in mid July if everything goes right.
Old Jun 27, 2007 | 03:00 AM
Gun5's Avatar
ya my friends with Ls1 cars love the strut bars so i think im gonna jump and get one (**** it) might as well blow money on something else look forward to the tests hopefully i dont have that other **** by then
Old Jun 27, 2007 | 03:03 AM
the_merv's Avatar
Veteran: Air Force
I hear ya.. that is a $5 ABS Delete right there..in theory it should work, everything is in the correct place.
Old Jun 27, 2007 | 11:04 AM
A-man930's Avatar
Subscribing...
Old Jun 27, 2007 | 12:29 PM
imnotplutonium's Avatar
made a HUGE difference in braking. oh and the strut tower brace is great too. the install was pretty straight forward... i heard from the guy who did it for me
Old Jun 27, 2007 | 02:25 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by A-man930
Subscribing...
You keepin an eye on this..
Old Jun 27, 2007 | 02:36 PM
LT1MAN's Avatar
i felt an all around improvement with my three point strut tower brace, although i did it at the same time as TA/LCAs/PHB. even in hard straight line braking it felt much more solid.
Old Jun 27, 2007 | 07:10 PM
A-man930's Avatar
Yep
