header gaskets and locking bolts?
Header bolts do not loosen, gaskets compress with makes the bolt lose torque at which point it can begin to back out. That is a symtom not the problem the problem is gasket compression. I actually try to leave it sit overnight and retighten before ever firing the car then carry the wrenches in the car so I can even give them a check before leaving work.
I cannot stress how much of what he is saying is the truth X1000.
Retighten every chance you can for several heat cycles. Then when you change oil check again. Mine are stiffer than Ron Jeremy on Viagra now!
1' ARP header bolts all the way.
+1 . Thats what I did and I havent retightened them yet and its been a few weeks . No leaks either . I have always wondered why people want to use anything other than the MLS gaskets .
They are reasonably priced as well
