Relocating the ABS Module...
Old Jun 28, 2007 | 01:06 PM
White_LightningZ's Avatar
Default Relocating the ABS Module...
I want to run a custom 3.5" CAI with no pinch in the pipe which is normal at the abs location. I was thinking of moving it somwhere on that side of the engine bay or anywhere convenient. Pics would be great - thanks
Old Jun 28, 2007 | 01:12 PM
thesoundandthefury's Avatar
Unless you've done something like a battery relocation and freed up the space on that side, I really don't see where else in the engine bay you could move an ABS modulator to. Why not just delete it and save yourself a boatload of hassle?
Old Jun 28, 2007 | 01:40 PM
Formula350's Avatar
Why not convert to Speed Density and just run the conical K&N directly off the TB and get rid of every bend? I mean, the CAI's are designed with flow in mind, so that bend really isn't as restrictive as you're thinking. Plus, you still have the TB elbow to deal with, so it's moot.
Old Jun 28, 2007 | 01:43 PM
Fastbird93's Avatar
I wouldn't do that. I've personally seen where that will act like it's giving more power when on the dyno, but under a closed hood you'll be pulling in hot air and you WILL be costing yourself power.
Old Jun 28, 2007 | 01:44 PM
Formula350's Avatar
Fair enough
