155 mph speedo swap???
1993 LT1s can use 1993 LT1 Clusters, tach wont work with a 94-97 Cluster.
1994-1997 - Can use any cluster from 93-97 with out issues. A lot of guys swap to the newer 97 style.
1998-2002- Will not work correctly in a LT1, if you want that style, you have to use a 1997 LT1 cluster.
115 Vs 155
Cars that don't have RPO code "QLC" for the Eagle 245/50/16 GS-C Z Rated tires got the 115 Speedo. These cars didn't get the performance package, which came with upgraded 3.23s from 2.73s in autos, and oil coolers, RPO code "K4C." All 1993 Trans Am came with the performance package, later called the GT in 1994, came with the high rise spoiler, 155MPH speedo and so on. The Formulas and Z28s how ever didn't come standard as such. After 1993 all six speeds came with the standard 3.42s, 155 Speedo and so on. How ever in 93, the Z28s and Formulas had two six speeds, an M28 with 2.73s and a M29 with 3.23s, all TA six speeds were M29 "wide Ratio," cars. Not necessarily the case with the Formulas and Z28s. I believe in 1996 the high rise spoiler was once again standard equipment.
Sara Lou
