NoooOOO!! LT1 Hydrolocked!!!!!!!!!!
Old Jun 30, 2007 | 09:58 AM
supaspowt's Avatar
Default NoooOOO!! LT1 Hydrolocked!!!!!!!!!!
Please somebody, give me options! Preferably under $1500
Old Jun 30, 2007 | 10:23 AM
dhdenney's Avatar
Pullouts.
Old Jun 30, 2007 | 10:53 AM
z28hustle's Avatar
whats hydrolocked? and how did it happen?
Old Jun 30, 2007 | 10:56 AM
dhdenney's Avatar
Water in the motor. I think the most common way is blown headgasket.
Old Jun 30, 2007 | 11:10 AM
supaspowt's Avatar
I was Seafoaming and everything was going well until it shut off. Any suggestions would be appreciated.Thanx
Eric
z28hustle's Avatar
ouchies....
Old Jun 30, 2007 | 11:17 AM
96capricemgr's Avatar
Pull the plugs then crank it over. Seafoam should come spraying out of the offending cylinder.
Hydrolocked means so much fluid in the cylinder that the motor wont turn over because it can't compress it.
This is why I am hesitant to recommend seafoam on an LT1, the available vacuum fittings are all located so that one or two cylinders are going to get alot and the others almost nothing. A high volume squirt bottle through the TB I believe does a more even job. The engine will run with the boot off the TB so long as the MAF is unplugged, will set a code but no big deal.
Old Jun 30, 2007 | 12:23 PM
dhdenney's Avatar
Edited my post. I guess since Seafoam got popular, probably the second most common way to hydrolock a motor.
Old Jun 30, 2007 | 12:24 PM
supaspowt's Avatar
Thanks man- Ill pick up some more plugs on the way home and try to drain the cyliders. I was also hesitant for the same reasons, but a spray bottle being squirted into the brake booster hose was thought to be the way to go. Ill post an update this evening.
Old Jun 30, 2007 | 12:46 PM
95 Camaro Z28's Avatar
if its truly fucked over, i got a motor for sale its not 1500...its quite a bit more but its a bad *** set up and only has 7k miles on it, shoot me a pm if your interested. the price im asking is a steal compared to what it had cost and if you need to rebuilt your motor anyways, this is a better alternative! 7k miles, ready to drop in with plenty of extras. like i said pm me if your interested
Old Jun 30, 2007 | 03:00 PM
supaspowt's Avatar
Alright, that have seemed to work it started but I have major clatter in my driver side valve cover. It gets worse with higher RPM's. Other than that it sounds pretty good All I can hope for is a bent pushrod or valve, or loose rocker or spring or..................... I dont feel like pulling the cover now,plus its 110 degrees outside
Old Jun 30, 2007 | 06:51 PM
the_merv's Avatar
Veteran: Air Force
Hope it works out for you man..I have never even used that ****..probably cause I keep building new Engines..
Old Jun 30, 2007 | 07:27 PM
Formula350's Avatar
Never heard of getting hyro'd from a seafoam job lol That's a bummer
Old Jul 1, 2007 | 11:13 AM
dhdenney's Avatar
Maybe not that but I see quite a bit of stuff about "I Seafoamed and now the engine............"
Old Jul 1, 2007 | 02:01 PM
radioren's Avatar
Great I was planning on seafoaming my 95 t/a and giving it a complete major tune up. I have 88,000 on the clock. Ill post thread for those who have seafoamed your lt w/ no issues
Old Jul 5, 2007 | 02:32 PM
supaspowt's Avatar
has a bearing or 2 clakking around
oh well you live and ya learn.
Old Jul 5, 2007 | 03:10 PM
the_merv's Avatar
Veteran: Air Force
You have a chance to figure it out..
Old Jul 5, 2007 | 03:15 PM
imnotplutonium's Avatar
this is why I am so hesitant to do it myself. I have 114XXX on the clock and she still runs great.... at the moment. haha
Old Jul 5, 2007 | 06:22 PM
James Montigny's Avatar
Sorry to hear about that man, I sure hope you can blow it out the plug holes
and get her back up and running.
I thought I had locked mine up a while back, fortunately I got it running again.
I couldn't help but think it was a great excuse to build a forged 355, but a horrible time.
Old Jul 5, 2007 | 07:30 PM
supaspowt's Avatar
Originally Posted by James Montigny
.........excuse to build a forged 355,......
I am collecting info and doing my homework on a 396ci build, and maybe a 100 shot When I get all the peices together Ill start posting progress pics.
