misfire diagnosis help.
If you have a misfire that you can actually hear/feel, then you have a real issue and an lt4 knock module will do absolutely zero to help you with that.
In summary, an lt4 knock module will not fix real engine problems. i.e. misfires, rough idleling, audible knocking, etc. The only thing an lt4 knock module will do is sometimes reduce knock retard due to a false knock condition, and even in that case it's usually less effective than tuning which is the better solution.
Mike, thanks i will check out the opti harness tomorrow.
