LT1 Free Mods
Worth mentioning it's only available on the 94+ models with the 4L60E, and not the 93's with 700R4 (4L60)
What is the Air Inlet Elbow tube free mod? I havent heard of that one
Now, it is possible to wire the shift button into the Z28, but there is really no point. The only real life time I would think you would want to have that option, is if you switch tires sizes a lot, say 26in street tires, to 28in drag radials ... you can then switch between 2 shift tables with the touch of a button, and correct any shift point issues the new tire size might cause. Other than that, it really isn't worth the time.
http://www.putfile.com/pic.php?img=6056832
Good job of explaining it...thats exactly what it does.
The ONLY free mod I found that was worth a damn and worked correctly is taking wieght out of the car
All others are crap!
BTW as far as the screen mod?I have not had one since 97 and never once had an issue even with a 96 or 97 PCM
James
heh)
