Attention Moderators:
Old Jul 6, 2007 | 02:26 PM
dhdenney's Avatar
Originally Posted by 96capricemgr
People get hungup on peak numbers which often occur at high lifts you can't keep the valve open too for very long and many heads that flow over say 300cfm do not flow anywhere near as well as a worked stock casting does .400 and below where the valve spends a lot of time.
Somewhat in the realm of discussion here........ I bought a set of LS1 853 heads and they were flowed by the porter. I actually don't remember all the numbers but I remember at peak lift for my cam, it was gonna be like 300 cfm or something. A decent head in other words. So I took the flow numbers for my heads, AFR 205's, and some Patriot stage II LS1/5.3 heads and put them into Excel. I graphed the numbers just to see what the curves looked like. The low lift numbers for my heads were obviously higher than the AFR's and had a pretty good looking curve. Mine had stock sized valves too. I didn't save any of the data, I just wanted to see. Granted this is three different flow benches but the bore size was the same so it was good for comparison purposes.
