Knock Module
Old Jul 2, 2007 | 09:38 PM
B4CZR2's Avatar
Default Knock Module HELP!
My question is this: How important is the Knock module in a OBDI computer, and what happens to the car when It is removed?
So here is the story; I bought the car from my friend and a few years ago he took it to a GM dealer to run a diagnostics on the car. I remeber him paying about $80 for it too! Well I bought a computer from a friend and installed it today. The new computer had it tuned for a gears, cold air intake, Long tube headers and the AIR and EGR romoved. All of which is what I have done to my car so far. Well when I was swaping in the new computer, the old one which I thought a had a LT4 knock module in it, since I was the one who installed it for my friend some time before he brought it to a stealer, only to find out it had been removed! Now What would that do to the performance of my car having no knock module at all (LT1 or LT4) in it? I took it to the track this past weekend and ran some really sad times, sad enough where I would almost rather race my ZR2 instead or cry!
Old Jul 2, 2007 | 09:43 PM
97LT1's Avatar
man that might have an impact on what the computer sets timing at for sure.
I dont know all there is about the OBD1, but it would seem that if it didnt get a reading it would be throwing a code or retarding by default.
Old Jul 2, 2007 | 09:49 PM
B4CZR2's Avatar
Well it hasn't thrown any codes that stay on for longer than a minute after I just installed a new MSD Pro Billet opit, plugs and wires, OR LT Headers & Y with a cut-out. Befroe with the opit that was WAAAY beyond shot it never threw any codes. But after all the work I did I couldn't pull more than .4 sec off my quater mi times when the car misfired and ran likte complete ****! Not to mention I get at best 14,5 mpgs! It sucks! Makes me really pissed... well enough venting
Old Jul 2, 2007 | 10:38 PM
Formula350's Avatar
It has NO KM, or just the factory LT1 KM? If it's the stock LT1 KM, don't panic.
Old Jul 3, 2007 | 07:57 AM
97LT1's Avatar
Just buy a LT4 KM or even a LT1 KM and put it in, and be done with it. Just monitor your results.
Dont worry I am getting 13.9 MPG right now. (tracing that prob)
Old Jul 3, 2007 | 08:03 AM
indirocz28's Avatar
Werent you putting a cam in that thing?
I recently dynotuned my car and it made good numbers N/A. However, if i open the cut outs, or am just cruising around town it sets off the knock module and immediately retards the timing like 12-14 deg, but when im on it it goes, and goes good..
I am buying an LT4 KM this week from www.gmpartsdirect.com
$52.00 shipped..
Old Jul 3, 2007 | 03:26 PM
B4CZR2's Avatar
I opened up my computer and there wasn't even an KM in it! It does run better now that there is one in it... I'm hoping the MPGs will get a little better now
Old Jul 3, 2007 | 03:38 PM
Hot94Z28's Avatar
Well even if you get a tune they say a LT4 KM is a better filter than the stock anyways.
Old Jul 3, 2007 | 04:20 PM
B4CZR2's Avatar
Well I have an LT1 in it for right now, but I will be hopefully getting an LT4 in the next few days.
Old Jul 3, 2007 | 04:39 PM
97LT1's Avatar
Yeah if you gonna cam or make you car louder, it is a good upgrade to reduce BS false knock.
If you get a scanmaster or datalog program you can monitor these things, and take the guesswork out. I am almost sure that you were getting max or close knockretard with no module. I know they can program or desensitize the actual knock sensor that is in the block, but that is more extreme.
Old Jul 3, 2007 | 05:27 PM
Razor_Blade's Avatar
Now I'm not sure about the module its self, but having the knock sensor unhooked adds 9/10 of et and drops 7 mph on my car. I don't feel like typing enough to explain exactly how I know this, but it was on back to back passes, with no other changes.
Old Jul 3, 2007 | 07:11 PM
infinitebird's Avatar
That's because unhooking the knock sensor will set a DTC that will pull a huge amount of timing. If you want to delete the knock sensor you have to tune it out in addition to unhooking it.
Old Jul 3, 2007 | 10:38 PM
The OP was asking how much performance he might be losing, since his car didn't have a knock module in place. I simply informed him how much my car lost on one pass from not having the knock sensor hooked up, because I thought it might be relavant to his question. I'm well aware of what caused the decreased performance.
FYI, With a little research the knock sensor can be bypassed without touching the tune and it won't pull timing.
Old Jul 4, 2007 | 09:56 AM
B4CZR2's Avatar
That was pretty much my question guys, I was running horrible times at the track. I ran 3 passes on a 70 degree day with low humidity and I could only best a 14.7 at 93. That was really dissapointing after all the work I did to it. So if it should gain 9/10ths of a second then I will be right where I should be, 13.8 or 13.9. And then as I said before, I hope my gas mileage improves too.
Old Jul 4, 2007 | 01:44 PM
cool, I was just providing additional info, wasn't trying to call you dumb or anything
