code 51
Old Jul 5, 2007 | 05:14 PM
blue94's Avatar
Default code 51
eeprom programming error...anyone ever had this code show up. This code came up on me today and code 36 optispark high resolution signal faulty came up a few days before that.
Old Jul 9, 2007 | 03:45 AM
blue94's Avatar
now i am also getting code 42, ICM circuit, short or grounded, and 44-Bank 1- left O2 sensor lean. I just recently replaced the ICM and coil, could I have done something wrong causing it to throw these codes?
Old Jul 9, 2007 | 09:43 AM
dhdenney's Avatar
Opti code is self explanatory. If that stays, then you may be looking at a new one. As far as the O2, ICM codes--check your ground there on the driver head. Could be the issue but it won't cost anything to turn a few nuts and bolts.
