Comp XFI 230/236 questions
Originally Posted by GreatWhiteZ28
obvisously it does, cause A no valve is supposed to be open when the piston is at TDC, which is was. Simply put, The timing was off..
If the intake valves were open a lot at TDC you may have bent them. I'd do a leak down!
