lt1 into an 87 ta will it fit?
Old Jul 7, 2007 | 08:41 PM
blue beast's Avatar
Default lt1 into an 87 ta will it fit?
well i have the chance to get my hands on a lt1 from a 96 impala that was crashed.it only has 53,000 on the clock.i just need to know if it will fit my 87 ta thats been sitting for the past two years.any input would be great to have from anybody that has done it before.
Old Jul 7, 2007 | 08:57 PM
Formula350's Avatar
I think the 3rd gens need a K-Member, but I'm not 100% sure since the engine mounts are the same.
Keep in mind, that Impalas LT1 MAY be a Baby 4.3l LT1. Will still be better than the motor in the 87, unless you have a 350 TPI, in which case it'll be close to the same, but the TPI will make about 40 more ft/lbs. If your car doesn't have a motor, or is blown, that's another story. The transmissions should bolt up, but you'll want to either run your stock one, or take the 4L60E and the WHOLE wiring harness from the Impala and put into yours.
If the Impalas motor is cheap/free then go for it. But you'll need all the wiring for the motor, which will include the transmission. So my FINAL answer is get the motor and trans and all the wiring. You'll need a modified trans cross member for that 4L60E (80% sure)
Old Jul 7, 2007 | 09:06 PM
96capricemgr's Avatar
The 4.3L V8 was ONLY in the base Caprice sedans. 94-96 Impalas always got the LT1 as did the 94-96 Caprice and Roadmaster wagons, Roadmaster sedans and Fleetwoods.
he Impala LT1 is no different from any of the other b-body LT1s meaning the same as a cop car one(were available with the 4.3ll99 but LT1 was optional) or grandma's wagon. So do not pay extra for "Impala" parts.
It will fit fine, a friend has a LT1 in his 91 RS first with a 4L60E and now a T56.
Old Jul 7, 2007 | 09:15 PM
Formula350's Avatar
Fair enough I figured the Impala got the 4.3 and the SS got the 5.7.
Old Jul 7, 2007 | 09:45 PM
There was on "Impala" just the Impala SS and that frankly was basically just a trim package on a Caprice, standard LT1, less chrome, interior was gray leather PERIOD, got 3.08s as opposed to 2.93s, got rear discs with the same drum proportioning valve the rest of the cars got so they are barely functional and stock for stock a step backwards from the drums. Honestly those are the highlights.
A lot of people cry foul when I say the stock Impala rear discs are a step backwards from the standard Caprice drums, trust me had both in the same car. GM was too cheap to make a proper disc proportioning valve so in normal light driving the rear discs barely apply. Guys have figured out how to modify the prop valve and make the discs function properly at which point the discs perform as they should.
People love to put it up on a pedestal it does not deserve.
Old Jul 7, 2007 | 10:09 PM
Formula350's Avatar
And this is why you're the B-Body guy lol I never paid much attention to B-Bodies other than I knew the SS was one hell of a beautiful car.
Old Jul 7, 2007 | 10:28 PM
the_merv's Avatar
Veteran: Air Force
He's got one that goes like hell..I am not into the "Taxi Cabs"..but anything can be done.
Wouldn't mind having a late 70's Cadillac runnin 12's..
Old Jul 7, 2007 | 11:54 PM
Burning Rubber's Avatar
It will bolt right in there. i just put one in my 91 RS
Old Jul 8, 2007 | 12:31 PM
92LT1RS's Avatar
see my screen name, yes it works just fine. no you don't need a k-member to do it. if you want to keep a/c with an F-Body LT1 you have to notch the crossmember though.
Old Jul 8, 2007 | 07:36 PM
Zralou's Avatar
Will the radiator need to be changed too?. Also, weren't the 'B' bodies Iron headed?.
Sara Lou
Old Jul 8, 2007 | 08:32 PM
Yes the b-body motors were iron headed but stock for stock they are slightly better than most of the aluminums.
Old Jul 8, 2007 | 09:53 PM
92LT1RS's Avatar
Sara Lou
nope, keep your stock radiator. I converted to dual fans though. for radiator hoses I'm running an F-body upper hose and I think a Corvette lower hose. could be the other way around.
Old Jul 10, 2007 | 07:18 AM
supaspowt's Avatar
http://www.youtube.com/watch?v=IQDfSRNja1k
..and fast
Old Jul 10, 2007 | 07:25 AM
supaspowt's Avatar
This should grab a lot of attention
mid 9's at 149mph
http://www.youtube.com/watch?v=OwrtW8R0ATg
