Which headgasket do i Need?
Old Jul 11, 2007 | 12:14 AM
94Z28man's Avatar
Default Which headgasket do i Need?
I have an LT1 with a stock bottom end and edelbrock ported and polished heads. I want to go with the SCE Pro Copper gasket but I dont know which bore or thickness I need.
Old Jul 11, 2007 | 01:37 AM
SincalT/A's Avatar
if you want to stay stock compression then go 0.039 thickness and 4.000 bore.i'm not sure if they carry that size but,it's a good start.you might be little higher than stock if your combustion chambers are
smaller than 58cc.
Old Jul 11, 2007 | 02:31 AM
speed_demon24's Avatar
smaller than 58cc.
Stock gaskets are .050" and the stock chambers are 54cc.
Old Jul 11, 2007 | 07:28 AM
dhdenney's Avatar
Edelbrock heads are 54cc so with a Fel-Pro .039 gasket, you'll bump the CR a little. Probably don't need the copper. It's a little overkill if you're not running big boost or a big shot.
Old Jul 11, 2007 | 06:42 PM
vanilla89's Avatar
On a stock bottomend i would use a impala gasket...
Old Jul 11, 2007 | 08:38 PM
urbanhunter44's Avatar
i went with the thin Mr Gasket impala gasket. Works great
Old Jul 11, 2007 | 09:43 PM
the_merv's Avatar
Veteran: Air Force
Felpro #1074 is what I used in mine..that is the .039" one.
Old Jul 11, 2007 | 10:56 PM
Formula350's Avatar
Silly question. Wouldn't using a thinner gasket increase the lift on the rockers due to moving the head closer to the engine, making the push-rod 'longer', essentially creating more lift? I mean obviously not a lot, but some yes?
Old Jul 11, 2007 | 11:07 PM
You have 2500 posts and you posted this???
Old Jul 11, 2007 | 11:10 PM
the_merv's Avatar
Veteran: Air Force
No..never..here is why.
Think about the Geometry..you are not changing the Rocker Angle with the Valves, merely raising the pivot point a little bit, cause these Heads use Stud-mount Rockers.
On LSX Engines is where you want to change the Push Rod length, cause the Rockers are mounted in a fixed position on the Head, and they have to be on the money..
I love them things too..22ft/lbs torque and they are set..
Old Jul 12, 2007 | 12:33 AM
Formula350's Avatar
Well thars my problem! I failed geometry Unless you're talking about geometric location, which then I don't quite follow. Either way, a "no" is a "no" and that's all I needed
Post count Knowledge. I hope I'm there to point and laugh at you when curiosity spurs a question and you decide to ask. I'll refrain from thinking outside the box from now on.
Old Jul 12, 2007 | 06:49 AM
SSweet97's Avatar
Ditto, that's what I'm using without any problems.
