Cometic head gaskets
Old Jul 11, 2007 | 11:18 PM
95FbFormula's Avatar
Default Cometic head gaskets
IS anyone running the 4.040 bore cometic heads gaskets on there 355. I am thinking about running it but do not want to have any problems since most head gaskets i see usually have a bigger bore. My compression will be about 11.6:1 with these.
http://www.cometic.com/da_viewimage.aspx?da=9
Old Jul 11, 2007 | 11:19 PM
OutlawZ's Avatar
Wouldn't that be a 357????? I don't see a reason why you couldn't.... They make a .040 cometic gasket i'm sure..... it's all about choice. high hp and or power adders and you should be using a good gasket ie cometic....
Old Jul 11, 2007 | 11:45 PM
lol sry its late my typing sucks. I meant to say i am running a 355 and want to use the cometic head gaskets with a 4.040 bore. usually head gaskets have bigger bores like the felpros with a 4.125 i just didn't want to run into any problems. but it looks like i wont so thats for the advice.
Old Jul 12, 2007 | 12:27 AM
Formula350's Avatar
I can't see any problem either since your bore is .030. But if 'normal' size is 4.125, why not just run a 4.050 then?
Old Jul 12, 2007 | 01:37 AM
speed_demon24's Avatar
I'm running 4.01" .027" cometics on my stock bottom end.
Old Jul 12, 2007 | 09:24 AM
T/ALT1's Avatar
I just got mine running with Cometic 4.040 gasket but .030 thick and mine is a 355" everything seems fine to me.
Old Jul 12, 2007 | 09:57 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I ran the 4.040 / .040
