Throttle bypass ???
http://shbox.com/1/tb_bypass.jpg
Other than the general "RTFM" post I'd usually do. It's good for 6-10 dynoed rwhp. Varied per car, and per application. Takes 3-5mins to do, and all you need is 2hose clamps and a 1/4" hose butt connector (pretty sure it's 1/4").
http://www.ws6.com/mod-8.htm
Why? For what? The coolant passages aren't vacuum fed. They are just that, a passage.
Cosmetic purposes, IMO it looks a lil cleaner with the ports caped.
now THAT'S clean looking. Guy I bought my 58mm had that done. Shame I didn't keep it -_- So many things I let go on the 91 grr. Oh well, I have the 58mm still
I was double jointed enough to change the #2 plug under the alternator without removing it - wonder if I can use that same "dexterity"
to do that hose without removing alternator brackets.How much coolant should I plan on dripping when I disconnect?
