fuel pump?
Old Jul 12, 2007 | 08:45 PM
1slot/a408's Avatar
Default fuel pump?
i need to purchase a new fuel pump! any suggestions? what are you using? also water pump? should i go for a new stock unit or go with aftermarket eletric? thanks for your help
Old Jul 12, 2007 | 09:07 PM
1slot/a408's Avatar
Granatelli GRN-GM722-2..any experience on this fuel
pump???
Old Jul 12, 2007 | 10:00 PM
1slowZ28's Avatar
Walbro pump kit. Doing fine for me so far, very good price to. Got mine a New Era Performance > $98 http://www.neweraperformanceparts.com
As for the WaterPump depends on what you want. Could do either. You have to make a few mods to get the electric to fit, but not to hard. Electric pumps don't flow as much, cause it's the same flow at all times. There both about the same price.
Old Jul 12, 2007 | 10:07 PM
dhdenney's Avatar
I vote for the stock replacement water pump. GMS fuel pump working good on mine so far. about 12K miles over 5 years.
Old Jul 13, 2007 | 03:35 AM
losaltos6's Avatar
Well i have an Airtex one that i have been trying to sell for a long time now, ever got to useing it man so if you want to buy hit me up and ill hook you up man.
Old Jul 13, 2007 | 05:03 AM
Ralls's Avatar
I asked this a little while back and was suggested Racetronix. It came with really good directions and I still love it. Racetronix uses a Walbro fuel pump, which is really good.
Old Jul 13, 2007 | 11:12 AM
93 blackformy's Avatar
+2 for Racetronix/Walbro pump kit....works great 4 me.
Old Jul 13, 2007 | 02:10 PM
ToxicFormula's Avatar
+3 for Racetronix/Walbro pump kit. I love mine and the instructions were great
 Michael S. Palmer
Old Jul 13, 2007 | 07:37 PM
LT1Formula007's Avatar
If your gonna do it, might as well go with the best. In-tank racetronix Walbro255lph fuel pump. I love it, and the directions were easy to understand. Putting it in is a different story, I should've cut a trap door out in the back....But didn't want to hack up the car. Good Luck!
Old Jul 14, 2007 | 12:59 AM
Ralls's Avatar
I regret how I did my install aswell. I dropped the tank while keeping the rear end in. I ended up cutting the filler neck because that was the only thing holding me back. It wouldn't of been as bad if I had known there was a vent tube inside of the filler neck. So I put it back together with a small hose on the vent tube and a large *** radiator hose for the outside.
Next time I'm cutting a trap door
Old Jul 14, 2007 | 03:12 AM
Yea I cut the hatch....easy as pie ....makes future ones easier too, as far as getting to it.
