Car wont start! Need help ASAP
The ICM checks out fine (Advanced Auto checked it 5 times and it passed all 5 times). We did a test using Shoebox's website where we used a volt meter on the ICM with the key on but didn't get anything there. We're not sure where to go from here?
Please some one help me so I can get this out of the garage.
Ad definitely make sure all the grounds are connected properly.
Those two grounds I mentioned in my first post, would those cause any problems?
Have you got constant Fuel Pressure now that you connected it, and have you connected the Grounds?
Well in that case, you might have a bad coil, or a bad connection between the coil and pcm.
And yeah you definitely want all grounds to be connected.
I carefully connected everything when I put the cam in and spent quite a bit of time making sure the opti was installed right so I don't think thats it. This week I am getting a new opti harness because the opti side clip on mine is broke and it just kinda sits in the plug for it. Theres a small chance this might be the problem but I just haven't been able to do anything with it because all the dealerships were closed by the time I figured it out.
Maybe this is Jesus saying I just need to LS1 swap my car instead.
