ready to blow up motor, cant figure out problem
I feel your pain man... I am having the same exact problem and my whole motor only has 1000K on it since the rebuild.. but i am getting a ticking noise from the rocker and pushrod from the #4 cylinder... so i am waiting for my car to cool down and i am going to go outside and try to figure it out
Originally Posted by daniel6718
rockers normally wont get oil at idle...youll need 2500 rpm or more to get oil at every rocker....
also aftermarket valvetrain does make more noise than stock...maybe put the cover on a listen...
I THINK I FIXED IT!!!!!!!
In the whole process i noticed more then normal rubbing on the one pushrod. So i took off the studs and inspected the guideplate. And wouldnt ya know, the noisey one had rubbed away some material away from the guideplate. So i put it back on and got the guideplate as low as i could get it and tighted it down. Ticking gone and now getting oil!! Im crossing my fingers untill tomm. when i could run the car more and really be sure. But as of right now its all good!!!
