Stall Or No Stall For Lt1/nos
Old Jul 15, 2007 | 08:05 PM
speedylexus2006's Avatar
Default Stall Or No Stall For Lt1/nos
I Was Told Lt1 Stock Stall's Are Excellant For Nos?
Nos Love Stock Stall's???????????????????????????????
Im Running A 150shoot And Was Wondering If I Should Order A Stall Or What.
Im Ordering A 3.73 This Week And I Have A Stock Sus.,trans And Motor.
Old Jul 15, 2007 | 08:37 PM
97blkz's Avatar
They like 3200-3600 Vig or yank stalls a whole lot more! Stall and spray best combo for an auto car.
Old Jul 15, 2007 | 09:22 PM
BizZzatch350's Avatar
Moderator
A good stall helps any combo, stock stall sucks for performance, thats why people knock .5 off their 1/4 times with a good stall.
Old Jul 16, 2007 | 11:01 AM
KMStevens's Avatar
2800rpm here, it launches hard enough that I can hook on the bottle on the street, but not so much so that it blows the tires off. cut a 1.61 on 17" et streets, never messed around with it with the stock stall.
Old Jul 16, 2007 | 06:09 PM
jakesz28's Avatar
3600vig here and it loves a 200 shot off the line!
Old Jul 16, 2007 | 08:42 PM
BlackScreaminMachine's Avatar
Internet Mechanic
A stall converter will help, now with the TQ curve of a n20 hit, its going to ramp it up faster then it would do on motor, that probably why people recommend stock stalls. Just be aware, you should get a converter built to take n20, also make sure the tranny is in good health. If you slug a converter in but burn the tranny, its new stall time again.
If you own a 94/95 car you need the stall wall fix if the car can hit above 2800 rpm, if it is 96/97, no issues. The stall should be rated around 3000, even if a cam goes it, it should match well.
Old Jul 16, 2007 | 08:52 PM
z28hustle's Avatar
what is this about a stall wall fix?
Old Jul 16, 2007 | 08:54 PM
z28hustle's Avatar
one of the main things i would think about is making sure that the tires you are using for that set up are meaty enough to handle that kinda violence off the line..
Old Jul 16, 2007 | 08:58 PM
Internet Mechanic
You can contact pcmforless, or madwolf, over on cz28.com its a PCM issue with ODB1 4L60e's that if the car sees 2800 or so rpms and the car isnt moving, it freaks out and goes into 3rd and stays in 3rd, makes you feel like you blew the tranny.
You need to turn the car off, and turn back on, I had a mild 2500 stall but with the 383, hotcam and M/T radials I managed to set it off, meaning all converters are different, all engine combos are different. Hell you can take the same company, have them make 10 converters and put in the same car and they are all going to vary a little bit.
Old Jul 17, 2007 | 06:38 AM
z28hustle's Avatar
ok thanks for the heads up
Old Jul 25, 2007 | 06:23 PM
JodyJ's Avatar
I have a PI 3600 and I was running a 200 shot. When I talked with Bryan via e-mail, he told me it was a hit or miss with his tune. He told me to load it up and give it a try (this was 1 to 1 1/2 years ago). i don't know if he actually has the fix, but I could be wrong.
I'm still have problems with the 1-2 shift. At the last race with the 200 shot, I hit the rev limiter on the 1-2 shift and had a nitrous back fire. This is what my intake elbow looks like LOL It blew the filter, maf screen, nozzle, iat sensor and opti tube off the car. I had to unplug the maf to get the car started and drive it home.
http://jody.dltechnologies.com/1le-02.jpg
http://jody.dltechnologies.com/1le-01.jpg
So, I may be putting my PI 2800 back in.
Jody J.
Old Jul 25, 2007 | 07:21 PM
koolaid_kid's Avatar
You need to fix the shift point, not change the converter. It is a tuneable parameter and is obviously set too high in your PCM.
Old Jul 25, 2007 | 07:38 PM
JodyJ's Avatar
I do have LT1 Edit and I did set the 1-2 shift MPH by 5 MPH and then 10 MPH and still the same results. I think I read somewhere that the computer is not fast enough, but I'm not sure.
Jody J.
Old Jul 25, 2007 | 10:13 PM
Stroked96Bowtie's Avatar
yikes...will a stock 10bolt hold that power?
Old Jul 26, 2007 | 01:21 AM
So What Kind Of Stall Would Be Good For Me ?
If You Can Provide A Link Where To Buy Maybe Ebay Would Be Nice Since I Do Have A Ccount There.
Thanks Guys For The Excellant Responses Especially "blkscreaminmachinne"
And I Do Have M/t D/r Already
Old Jul 26, 2007 | 09:19 AM
4thgenz's Avatar
stock stall and 150 shot w/ m/t et streets i cut a 1.62 60' my e/t streets were just a little too bald to hook on the street though...but did just fine at the track. im switching to the th-350 and gonna go with approx. 2700 stall. so i shouldnt need the "stall wall fix"....i think. lol please do correct me if i am wrong....but if im running an A3 the computer wont be able to shift into 3rd.
Old Jul 26, 2007 | 09:25 AM
dhdenney's Avatar
Speedylexus, get something in the 2800-3400 range. 4th gen, with a TH-350, you won't have to worry about stall wall. It's a 4l60e problem only.
Old Jul 26, 2007 | 10:07 AM
JodyJ's Avatar
I really liked my PI 2800 stall and N2O when it was installed. Then I even liked it more when I swapped in an aftermarket torque arm.
Jody J.
