LS1 Airlid Conversion, WITH PICS!!!
Man..you are havin an issue with this..
For someone who doesn't give that much of a **** about it you put up one hell of an arguement..
Tell you what..when I finish up today, I'll post pics of it on there with my new Engine..I suppose I wasted a perfectly good Car by putting that in also..
The issue I have is this, people chop up their car based on...what? Because you did it and you SAID it FELT faster? Did no testing whatsoever....NONE.
When you get your 15* headed LS1 together, It MUST have 10 more RWHP with that lid setup...you wouldnt have ANY problem running my SLOW 23* headed OLD SCHOOL LT1.....would ya? Motor to motor?
David
Is your setup exactly like the one in this thread? Or does it have the LS1 lower box and rad support on it?
David
David
I'll run you Motor to Motor..with my "LS1"..
You fail to read the Signature young Grasshopper..
I don't know why you are referring to the LT1 like that anyways..no where am I baggin on it...last time I checked I had one in my Car at one point in time..
David
the way i did mine i can get air either way. when youre at a stop it usually comes from the front and when moving the bottom
merv, i never thought id see the day.
I'm done arguing..I'll go have a more of a productive conversation with my Wall..
Ahhh Sooo, you also fail to read MY sig young one.
You made the statement"you keep going slow" Here is what I am going slow with.
[IMG]
[/IMG] I will be in Tulsa Ok in a month or so at Ed Wrights shop.....we can hook up after I am done. I got less motor in a heavier car...nothing to fear.
All I am after is PROOF.....If you prove me wrong I will shut up.
David
It sucks from the bottom IN FRONT of the radiator, if you cut it out RIGHT... the radiator remains blocked off so heat cannot enter the intake with the stock LS1 lower box.
THIS is the point I am trying to make here. Cutting the core support and laying the filter DIRECTLY on top of the radiator IS NOT the same as what an LS1 has. THERE IS NO LOWER BOX to block the heat from the radiator.
In theory when the maf sees less dense(hot) air and the air inlet temp sensor(ait) sees hot air the ecm adjusts fuel and timing and thus less power. IN THEORY.
If it were ME and I did that, I would attach a piece of sheet aluminum on top of the rad and condenser, make a little stand for the filter to sit on and drill holes in the front of the core support to pull air from the spot between the core support and the front cap, angle it down and pop rivet it to the plastic piece angled up in front of the radiator but hey that's just me.
I am a realist...I need proof...you guys can **** up a rope for all I care....If you want to do that to your car because you THINK it makes it faster....I got no problem with that.
Think for a minute, why do cars run better in winter? Cooler air, why to F/I cars run intercoolers? Cooler air, why do cars run better at sea level? Denser air(aka cooler) Why do racers keep up with the DA at a racetrack? Air quality...COme on guys.
Again, if you prove me wrong...I will go away..
MERV, engine looks awesome.
David
David
I'm going your route also, I'll just get a hood to clear instead of cutting things up.
Even if hypothetically it doesn't make any more power, it will make working on things easier. Having to pull the K&N CAI is a pain in the ***.
