Possible blown head gasket... With a twist!
Old Jul 17, 2007 | 09:23 PM
white95lt1's Avatar
Default Possible blown head gasket... With a twist!
Soooo
Car has been sitting for a while during a motor swap. I swapped in a 60K mile used motor i picked up. Put my cam and valvetrain in it and slapped it in. Flushed the motor out with about 5-6 quarts of oil and go it started. Let it run for a total of about 5-10 mins hunting down a vaccum leak/ idle problem. Got that straightened out and pulled a vlavecover to adjust the rockers and i found MILKSHAKE! s0o0 I pulll all the plugs out and all look about the same except for #6. Suspecting an obvious blown headgasket i ran a compression test on the cylender and 2 other random ones... The two randoms came in at 185 and 185. And the #6 registered at 195! and did not bleed down after 5-10 mins. So what do you guys think? I dont suspect any of the cylinders due to the fact none look "steam cleaned". Could the water have come from somewhere else?
Thanks in adavnce
Old Jul 18, 2007 | 01:38 AM
the_merv's Avatar
Veteran: Air Force
It is smoking..?
Old Jul 18, 2007 | 10:03 AM
dhdenney's Avatar
How much water are we talking here?
