launchin a A4
Old Jul 18, 2007 | 09:58 PM
cruzin94's Avatar
Default launchin a A4
I was wondering what every one is launching there autos at i was wonderin what rpm will the tires start to break loose with the stock stall and 2.73's when i was at the tack i held it about 1,100rpms to launch i was wondering what i could probally rev it to, to get a good launch
Old Jul 18, 2007 | 10:46 PM
RickyMartinZ28's Avatar
Well mine will fry them from idle with 3:23s... even at partial throttle, WOT is another story all together... I've gotten mine to about 1500 and played it cool coming out and came out pretty well. I need some DRs something terrible.
Old Jul 18, 2007 | 11:07 PM
xxcoolrollinxx's Avatar
yeah 1400ish and give it hell is what i do
i need a stall and 3.73's and DR's BAD !
Old Jul 18, 2007 | 11:34 PM
black_lt1_z28's Avatar
stock you should be able to hold till about 1600 before you start spinning, mine with 3.73s and a 2800 stall start to break loose at 2200.
Old Jul 18, 2007 | 11:44 PM
the_merv's Avatar
Veteran: Air Force
I used to break loose at around 2k. Thise new setup will roast them probably around 3000...the Engine will rev up that fast before the Stall can catch.
Old Jul 18, 2007 | 11:51 PM
fbodyfreek's Avatar
i stall to about 1400 and can cut a 2.0 sixty-foot with gears.
Old Jul 19, 2007 | 11:09 AM
titter's Avatar
I was cutting 2.0s on a stock stall with the stock 3.23's foot braking the launch from 1,600, and slightly feather, till around 2,900, than gave it hell. with your 2.73's, you might be able to get a little more RPM out of it, just have to try. 13.862 @ 99.65 2.010 60' was my best stock pass with that combo on some shitty street tires, with the only mod being the dreaded flowmaster! oh noes, even still had the stock air box ;] Just don't do a burnout, just a quick spin to clean off any dirt, and any of water you might of picked up going around the box.
Old Jul 19, 2007 | 11:14 AM
GreatWhiteZ28's Avatar
been launching it from 2,100 with a 1.75 60" on DR's, but then agian im using a 3200stall
Old Jul 19, 2007 | 11:19 AM
FAD2BLK93's Avatar
At the track I drop my air pressure down to 20 psi on street tires, I line up...hit the pre-stage beam...bring the rpm up to 1400...then barely go into the stage beam...then when I just see the third yellow come on take off...I usually cut between a .002 and .040 with a 1.94 to 1.98 60ft. and 13.50 @ 102.
Next level's Avatar
i was gonna say 1.75 60FT is ridiclous on a stock stall lol.
I stalled mine just under 2000 w/o issues then i blew up the trans and rearend lol but i was pulling 14 flat on my complete stock LT1.
Old Jul 19, 2007 | 01:39 PM
Lol...think the best 60' I ever cut with a stock stall was a 1.99 I think...don't think you can do any better than a 1.90 stock stall...I could be wrong, but that's just my .02
Old Jul 19, 2007 | 04:49 PM
cruzin94's Avatar
i would only rev till about 1,100rpms to launch and i got a 2.124 id like to pull a 2.00 or less on the street tires im goin to have to practice my launching but thanks every one for ur input
Old Jul 19, 2007 | 04:54 PM
what do you mean slightly feather ... like dont launch hard ?
thats what i do and ive been cutting 2.2 60's ... so if i stall up to 1600 and and ease really slow to about 2900 and then gun it i ll be able to get a 2.0 ?
Old Jul 20, 2007 | 01:29 AM
the_merv's Avatar
Veteran: Air Force
Yea..that would be impressive. I used to cut 1.94's on stock Stall with some BFG's Street Tires on it.
I plan on launchin around 4000RPM with the new setup..
See how long the 10-Bolt that I built up lasts on that one..
Old Jul 20, 2007 | 09:16 AM
titter's Avatar
You might be able to stall it higher with a lower gear ratio. Give it a try ... 2.2 isn't shabby depending on your track, gear, and street tires.
Old Jul 20, 2007 | 10:21 AM
Puck's Avatar
It will depend A LOT on your tires.
Can't you just give it gas until it breaks loose and find out what YOUR combo does
Old Jul 20, 2007 | 10:54 AM
z28hustle's Avatar
2 second 60 foots are craptastic guys.. time to get tires gears stalls suspension parts etc..
Old Jul 20, 2007 | 11:33 AM
Next level's Avatar
i agree like i said 1.5 almost 1.4 for me.
Old Jul 20, 2007 | 12:10 PM
Puck's Avatar
Old Jul 20, 2007 | 06:44 PM
my94blackz's Avatar
Totally stock auto with 2.73's, i get 2.0's. I leave at 1400. Got a 3000 stall laying here ready for installation.
