oil capacity
Old Jul 20, 2007 | 02:41 PM
dhdenney's Avatar
Originally Posted by FAD2BLK93
GM factory spec is 4.5 quarts with the filter...and 4 quarts without, all of you may be over filling your oil system...creating some drag on the crank=loss of horsepower. I personally use 20-50 royal purple with lucas oil full syn addative.
1/2 qt should not be hitting the crank.
Old Jul 20, 2007 | 02:42 PM
dhdenney's Avatar
Originally Posted by JTSLP559
i live in 110 in the summer and 30s in the winter. i bought this gunk motor flush stuff, it was on sale at wallymart. i dont know if i should try it or not? what do you guys think?
Use the Motor Flush. I have used it several times. Just make sure you drain it all out. Stay away from oil additives as already mentioned. If you are using a quality synthetic, then the additive is already in it.
Old Jul 20, 2007 | 02:59 PM
Ralls's Avatar
I don't see how you guys are filling it up with 5 quarts or less. I don't use an oversized filter or aftermarket cooler and it comes out to be like 5.7 quarts.
Old Jul 21, 2007 | 01:11 AM
JTSLP559's Avatar
i ran a quart of atf in it with the old oil. it cleaned the hell out of it. it came out like water.
Old Jul 21, 2007 | 01:15 AM
JTSLP559's Avatar
forgot to mention. what do you guys average on idleing oil pressure warm. and driving temp warm.
i noticed my temp gauge got up to 235 before my fans kicked on an it cooled down to 215? is that normal? my ls1 and cobra didnt see over 210..
trans question.. i have a slow leak coming from or just coming down on a steel hose on the right side of the trans. the car shifts normal in normal driving.. but when i stomp on it. it wont shift. itl hit the revlimiter and just stick there? if i let off alil itl go into the next gear? whats up with that?
please help!
Old Jul 21, 2007 | 09:01 AM
dhdenney's Avatar
What are you seeing? It's common for these things to show low while idling. As long as you're showing an increase in pressure as you accelerate, I would say that is normal.
I would also say that is pretty common on these cars. Stock fan settings aren't the best. Does the fans kick on automatically when A/C is switched on? Also make sure BOTH fans are kicking on for peace of mind.
please help!
Sounds like what you mentioned is a trans cooler line. Probably wanna fix that. Also make sure trans isn't already low! That could be the reason why it isn't shifting. Runs out of oil to pump. Just guessing there but that's the first thing that comes to mind when you mentioned that line.
Old Jul 21, 2007 | 10:54 AM
JTSLP559's Avatar
well idle is like 19lbs or so. and driving its about 40.. id like alil more than that so what can i do?
yea both fans are coming on automatically. they dont turn on when i turn my ac on. how can i get my car to run cooler? change the fan settings?
yea it leaks all over my cat. smokes like crazy. its not low. its in operating temp. so im not sure why its doing that.. the car was sitting for 2 ana half years?
Old Jul 21, 2007 | 12:38 PM
TwoFast4Lv's Avatar
Actually that is with the small fitler. If you use the big filter like most of us and rev High RPMs 5.5 is just right...even with the 20w-50 RP I run.
Old Jul 21, 2007 | 12:50 PM
JTSLP559's Avatar
maybe il do that.
nobody carries a trans cooler line? said i have to make my own? whats the deal with that
Old Jul 21, 2007 | 04:39 PM
dhdenney's Avatar
Yeah a little thicker oil might help you out on your PSI. On the trans line, might just see if those fittings need tightening. Otherwise, they'll have to cut you a custom length hardline, bend it, slide the fittings/nuts on there, and then flare it.
Old Jul 21, 2007 | 05:22 PM
scorpion_z28's Avatar
Mobil 1 0w40 all the way its the best.5 quartz + filter
Old Jul 21, 2007 | 07:17 PM
  #32
TravisTA's Avatar
Mine takes 5.75 quarts with the filter.
Old Jul 21, 2007 | 07:32 PM
  #33
JTSLP559's Avatar
thanks for all the help guys! i appreciate it! hopefully i can get this **** squared away.. i mean **** i got the car for 500 bux so alil tlc is needed.. just hope i can fig out the trans problem not shifting at WOT
Old Jul 22, 2007 | 09:56 AM
  #34
Looks like you need a Trans rebuild not just motor oil
Old Aug 18, 2007 | 07:01 PM
  #35
blk97z28's Avatar
5.5 Mobil one 5W-30 with delco filter!!
Old Aug 18, 2007 | 09:22 PM
  #36
LT1Falcon's Avatar
Originally Posted by borninatransam
um for those that say they buy the 5 quart jug, that jug is only a gallon, and a gallon is only 4 quarts. you might want to look at that during your next oil change and get an extra quart to go with it.
yea have you not seen the 5 quart jugs? i think pennzoil and castrol are using it now too
Old Aug 18, 2007 | 09:27 PM
  #37
Formula350's Avatar
hah I was going to ask just this question too because I thought it was 5.5qt.
Does year matter possible? Do all years use the older style big oil filter? Mine is a Fram PH30, and not the PH3980 (skinny long) which is the taller version of the PH3387 that all the cars take, like the 3800 V6's. I'll just have to check my engine catalyst (sticker on the radiator crossmember)
Now, I just have to check if this filter I got to see if it's the right one. It was in my buddies garage and he said I can have it, and he's a Chev guy so it's a good chance. Napa GOLD even! lol
Old Aug 19, 2007 | 07:57 AM
  #38
hyperzone's Avatar
I use them and have one right here in front of me... says "4.73L/5U.S. Qts" on the big bottle of Mobil.
