procharger or le2
Old Jul 22, 2007 | 01:41 PM
jays97 t/a's Avatar
Default procharger or le2
which one would be the better bet im thinking that the procharger will make alittle more hp but it also costs 2 grand more... im getting ready to get on full time at my job so ill be makin a lot more money so im going to do one of the 2 above and im going to get performabuilt tranny with 3000 stall and longtubes.
Old Jul 22, 2007 | 02:15 PM
vanilla89's Avatar
it depends on how much power you want to make???If you just want 400 to 450 rwhp i would go with the le2,it would have a lot fatter torque curve and you would be more happy with it on the street.
Old Jul 22, 2007 | 02:19 PM
dangalla's Avatar
i would not run a procharger without a built bottom end, thats just my opinion though
a le2 setup you can get by with a stock bottom end
Old Jul 23, 2007 | 09:50 PM
mpe331lx's Avatar
Le2, Then when you are ready, build the bottom end and slap a D1sc on it!
Stay away from the P1sc............JUNK!
Old Jul 24, 2007 | 02:56 AM
InsaneAuto86's Avatar
What if I get an engine rebuild with forged internals? Which will give more power?
Old Jul 24, 2007 | 02:59 AM
94'BLKBRD's Avatar
Yes you will be able to make more horsepower with a built bottom end because you would be able to run more lbs of boost.I would personally go with the LE2 package.
All Motor F T W !!!!!!
Old Jul 24, 2007 | 03:46 AM
94greencamaro's Avatar
the thing I would do if i were you is build the bottom end FOR BOOST....low compression forged internals, etc.
then slap le2 heads on it with a blower cam
run it until you have enough money for a procharger D1SC
and then put that bad boy on
I did it the wrong way and after a year it feels slow, and nitrous is the only thing i can do to it to make it considerably faster. So now im in the process of swapping out the bottom end and doing a D1SC setup that should be pushing 600 rwhp. Costs a lot less when you do it right the first time
Old Jul 24, 2007 | 04:02 AM
DroppedM6Z's Avatar
My LE2/GM847 combo was a great combo. I say LE all the way. Have lloyd grind you a cam or get a Bret Bauer like the cool kids
Old Jul 24, 2007 | 04:04 PM
scorpion_z28's Avatar
How many whp did you put with this combo?
Old Jul 24, 2007 | 04:12 PM
dangalla's Avatar
that was a joke correct, just want to make sure
Old Jul 24, 2007 | 05:25 PM
cruzin94's Avatar
i was thinking the same thing as you i was just wondering what one would be better and more streetable either decision you choose ur bottom end will probally go shortly after ......only if the procharger wasnt 5 grand id probally go with that
Old Jul 24, 2007 | 05:54 PM
dangalla's Avatar
i spent just under 5 grand to go from stock to le2 full bolt-on
but now if later i decide to go with a blower i will already have all the supporting mods, just need a cam and piston swap
