Intalling a tach.......question.....
Old Jul 26, 2007 | 11:22 PM
kokamo's Avatar
Default Intalling a tach.......question.....
Hey guys, I did an LT-1 swap into my 69 Camaro, I am not using the factory dash the 94 has so I don't have a tach.
I have a 5" Tach I want to mount in the car, but I'm not real sure on where to get my tach signal from. I know there is a tach input to the dash harness....should I use that wire or should I use the wire directly off the coil? Or is it the same wire?
Thanks for any help,
Joe
Old Jul 27, 2007 | 02:08 PM
ws6chicken's Avatar
Are you using the factory computer with the engine?
If so the pin out is right here
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
I'm pretty sure the out is 5v square wave that should would work with the auto meter tach.
and props to guy who made shbox.com
Old Jul 27, 2007 | 04:32 PM
Lt1junkie's Avatar
i think you can get a more accurate signal off the coil... I believe it is a pink wire but don;t quote me
Old Jul 28, 2007 | 07:43 AM
1lt1wiz's Avatar
yes u can use the coil i hooked mine to the black and white wire if i remember right.
Old Jul 28, 2007 | 11:15 AM
ws6chicken's Avatar
The coil and the PCM have the same signal, except the PCM has a distinctive "tach out" to "gauge cluster" so I guess it's just personal preference where you hook it up.
I had a data logger hooked up to the tach out pin and from what I saw it was dead on. (matching engine revs to EGT's)
