Cc306
Old Jul 31, 2007 | 06:37 PM
Revelation Z28's Avatar
Originally Posted by Matts94Z28
sounds like mine when it was close to stock. I think you would be okay with that oil pump...but then again they are cheap. Take a good look at your cam bearings while you in there too...the stress from the stock water pump grooved mine a little.
cant see the rear cam bearings that well with the engine still in the car. but the front one i may just replace.
Old Jul 31, 2007 | 09:20 PM
Matts94Z28's Avatar
Hell you can't see them well even with the motor out. Just check the front for excessive wear.
Old Aug 1, 2007 | 11:42 AM
Vicious95Z28's Avatar
i can leave my oil pump alone right?
Prolly. If you pull it down pay close attention to the front cam bearing. Mine was pretty worn and I feel like the water pump keeping it loaded had something to do with it.
