Good way to spend $700?
Old Jul 29, 2007 | 08:50 PM
Rowdy94's Avatar
Originally Posted by Koll
Not everything has to be afrom a performance stand point. Ever think that my current exhaust has a few problems and am just looking for the best fix? The $900 borla system sucks, and the magnaflow is $200 more than the hooker. Think that the $200 would be better spent elsewhere if I was going for performance?
You asked (in a performance forum no doubt!) what to do with $700. Then you started talking about aftermarket (READ: HIGH PERFORMANCE) ignition units and coils.
Pardon me for thinking you were interested in performance parts. I sure must've been way off base.
Old Jul 29, 2007 | 08:51 PM
Rowdy94's Avatar
Originally Posted by urbanhunter44
ah, didnt realize you had a caprice.
and are they true duals or do you have a cross pipe?
FWIW, an H-pipe (cross pipe) is still true duals.
Old Jul 29, 2007 | 09:00 PM
urbanhunter44's Avatar
A matter of local terminology I'm sure. In my neck of the woods true duals means true, as in no cross pipe, dual pipes.
Old Jul 29, 2007 | 09:28 PM
Rowdy94's Avatar
I'm not so sure. I'm pretty sure common terminology for true duals anywhere is anything that doesn't merge into one pipe.
Straight duals like you are referring don't make as much power in most cases. An X or H pipe improves the scavenging effect.
If it was just terminology, what would you call a dual setup with an X-pipe? It isn't single exhaust, so it must be dual.
Old Jul 29, 2007 | 10:03 PM
93 blackformy's Avatar
Agreed...IMO
