random misfire problem
Old Jul 29, 2007 | 03:13 PM
Black96Z's Avatar
Default random misfire problem
Yesterday my car started to random misfire. A friend of mine hooked it up to his scan tool and it misfired well over 100 time in a short period of time. I can't see no arcing anywhere. I was thinking that the ignition coil module or the opti is bad. It was running great one min. and crappy as hell the next.
Old Jul 29, 2007 | 07:25 PM
donkey mule's Avatar
Mine did this and has done this in the past. Sometimes you cant see it arcing even in the dark. Mine has always been spark plug wires and once an O2 sensor.
Old Jul 29, 2007 | 07:33 PM
mack's Avatar
Sounds like the opti IMO. Use a multi meter to check the coil to rule that out first. Check plugs and plug wire connections at plugs and opti second. Then check the opti.
Old Jul 30, 2007 | 07:38 AM
Black96Z's Avatar
How do you check the opti, coil, and module?
Old Jul 30, 2007 | 07:15 PM
mack's Avatar
Here you go, tons of info on the most common problems that occur with LT-1's and how to fix them. The info you need is located towards the bottom of the list after you click on the HOW TO's. Get your self a Haynes Repair Manual and multi-meter from your local parts store. Probably cost you about 30.00. Don't be affraid to make a mistake, that's how we learn. Paying a shop to do what you can learn is a waste of money that could be used for mods.
http://shbox.com/1/4th_gen_tech1.html
Let us know how it turns out.
Old Jul 30, 2007 | 07:27 PM
FAD2BLK93's Avatar
Usually if a coil is bad it goes dead, my sugestion is plugs and wires.
Old Jul 30, 2007 | 10:11 PM
A-man930's Avatar
I ran into the same issue lately. Can you hear any snapping/popping sounds when you're sitting in your garage? I started hearing those sounds, then it started running poorer, then the SES lit up, showing a random misfire. I would troubleshoot in the order of cost... least expensive first. Too bad plugs and wires on these cars are a complete pain Let us know how everything turns out.
Old Jul 31, 2007 | 07:54 AM
Black96Z's Avatar
I can't hea any snapping/popping sounds. I looked in my garage when it was night time with the lights off and I couldn't see any sparks.
Old Aug 1, 2007 | 09:06 PM
C5042081's Avatar
I had this and I just changed the fuel filter and put in a LT4 KM
made a huge difference
Old Aug 2, 2007 | 07:56 AM
Black96Z's Avatar
I all ready have a lt4 KM. I think I'll try the fuel filter first. It's the cheapest thing I could try.
Old Aug 14, 2007 | 08:57 AM
Black96Z's Avatar
New plugs, wires ok. Probably the f***** opti.
