2 bolt mains?
Old Aug 1, 2007 | 06:37 PM
cruzin94's Avatar
Default 2 bolt mains?
are lt1's two bolt mains and lt4's 4 bolt mains or are they the same or what ive been lookin it up and cant figure it out ...the reason i ask would it be better to build an lt4 if they are 4 bolt mains instead of a lt1 .... and if i build an lt1 engine would the 2 bolt main be somthing to worry about in a high hp motor?
Old Aug 1, 2007 | 06:53 PM
93 blackformy's Avatar
All Vette LT1 blocks are 4 bolt...F-bods is 2 bolt
Old Aug 1, 2007 | 07:17 PM
Matts94Z28's Avatar
Some f-bodies came with 4-bolt mains...like mine
Old Aug 1, 2007 | 07:29 PM
sdm1234's Avatar
yea the very last of the LT1s in the F-Bodies were carried over from the Vette's left-overs. mine is a 4-bolt main as well.
Old Aug 1, 2007 | 07:40 PM
I heard that before but how did Matts94Z28(1 post up from u) come with 4-bolt mains?
Old Aug 1, 2007 | 08:00 PM
cruzin94's Avatar
are camaros 4 bolt centers and 2 bolt ends or 2 bolt the hole block....and how much hp would a lt1 2 bolt hold up to saftly
Old Aug 1, 2007 | 08:03 PM
Matts94Z28's Avatar
It came from the factory that way. Im guessing it was left over from an LT1 vette
Old Aug 1, 2007 | 08:46 PM
Yea I'm not disagreeing with you I'm just trying ta understand, when they say "left over from the Vette" I thought it meant that since the 97 Vette's went with the LS1 only the/some of the 97 F-Bods got the Vette LT1 blocks that were'nt used in the vette...seeing as how you have a 94 F-Body(sig) I'm just wondering hows that...assuming everything I said was correct?
Old Aug 1, 2007 | 09:51 PM
95 Formula's Avatar
I run 2 bolt mains and my old motor went 5 years at 7000+. Before I rebuilt it I was going 7400 with the new heads. It is a 2 bolt main block and even had stock main bolt in it. I'm going back with 2 bolt mains but with ARP main studs this time. Made over 476 rwhp before it was torn down for a rebuild.
Old Aug 1, 2007 | 10:28 PM
the_merv's Avatar
Veteran: Air Force
A 4-Bolt in an F-body could also be a Factory replacement..
Old Aug 2, 2007 | 10:09 AM
Captainofiron's Avatar
Factory 4 bolt here
there is no casting number difference, only way to tell a 4 from a 2, is to pull the pan and check
to help blackformy understand, GM built X number of LT1 4bolt blocks for the Corvettes, since the vettes went to LS1's first they probably had an overstock of 4bolt LT1's, so since the Fbods still had LT1s they put them in those so that way they wouldnt have a ton of blocks sitting in a warehouse not to be used again.
capisce?
Old Aug 2, 2007 | 10:48 AM
LoL, I got that, at first I was just wondering how the guy with the 94 got one from the factory....and wondering if any other pre-97 people got one b/c it should be only a 97 thing..but it could be what Merv said.
Old Aug 3, 2007 | 01:28 PM
96capricemgr's Avatar
2 bolts will hold a lot more than most people are willing to admit and if you genuinely need 4 bolt you should be looking at aftermarket caps so even then a 2 bolt block is the better starting point.
Old Aug 3, 2007 | 04:31 PM
cruzin94's Avatar
after market caps? so why would a 2 bolt be a better starting point then goin and buy a used lt1 vette block and building that
Old Aug 3, 2007 | 05:19 PM
dangalla's Avatar
glad someone said that
Old Aug 3, 2007 | 06:14 PM
jakesz28's Avatar
2 bolt blocks will take a lot. If your pushing the envolope then a 2 bolt block with splayed (4 bolt) caps is the way to go. The 2 outer bolts will be at an angle to stop the cap from deflecting under heavy loads.
Old Aug 3, 2007 | 10:57 PM
go aftermarket splayed caps and they will be less likely to move than stock straight 4 bolts. Need a 2 bolt block to convert to splayed 4 bolt.
Old Aug 3, 2007 | 11:40 PM
97LT1's Avatar
Hmmm makes me want to peer under my oil pan on my 97. I will be doing a motor swap soon with 4bolt splayed, but that would be cool if I had a 4 bolt coming out.
Old Aug 3, 2007 | 11:47 PM
GOaT Cheese's Avatar
Holly Cow!! I think this is the first turly inteligent, educated and useful post I have ever seen on this entire board!
