weird issue
Old Aug 3, 2007 | 07:00 PM
jasonisdn's Avatar
Default weird issue
ok trying to crank the new motor. heres whats happening. car turns over fine and builds good oil pressure. i have spark and fuel, the msd opti is on correctly. new ign module, coil and battery. it turns over but never cranks. the voltage at the ecm is hitting 9 to 10 volts on the scanner, during cranking. i took a battery charger and hooked the ground cable to all the grounds 1 at a time. with the charger turned to jump start , to see if it was a weak ground. then i did the same with the starters hot wire. i checked continuity on all the grounds and power wires to make sure they have low resistance. all were at or under 1 ohm. i have even checked the ecm grounds on the ecm pins. i am lost nd out of ideas. i am using lt1 edit and am only getting a check sum error. it is also showing a high knock count as well. the plugs are gapped at .035 due to nitrous useage. any ideas?
edit
also when cranking and leaving your foot off the gas , it turns over easier. when you floor it so it will cut back on fuel , it will actually knock the voltage down alot lower.
Old Aug 3, 2007 | 11:39 PM
jasonisdn's Avatar
for those who give a crap , it was the versa fueler. for some unknown reason it was the entire probelm for todays issues. tomorrow is a new day. ZEX-Z i hope you are almost done with yours bud. i can feel the finish line tape now. i better watch out the tape will be made of rubber and bounce me back a few steps, knowing my luck.
