well im an idiot....
Old Aug 6, 2007 | 10:27 PM
ckyconan2003's Avatar
Default well im an idiot....
well i have the entire car together after installed the new cam. i am installing the hub last. i end up hitting it relentlessly with a hammer on the hub. seriously messing it up. so now ima buy a new one. this really sucks. Btw how close is the hub supposed to be to the freakin opti? like 1/8 in? cause its really close.
Old Aug 6, 2007 | 10:29 PM
Z8'S's Avatar
WOW!!! Never hit a hub with a hammer. You may need more than a hub now.
Old Aug 6, 2007 | 10:49 PM
Speed Density's Avatar
hashtagBMW
Chris is right.
You never want to make direct contact with the hub and something hard. Always use sort of a dampner (wood, Aluminum etc..)
Reason being, its to much direct shock to the internals.
Tony.
Old Aug 6, 2007 | 11:03 PM
Z8'S's Avatar
When I install my dampner I usally heat it up in the oven @350 for about 30 minutes and I will pull right on .No Beating Required.
Old Aug 6, 2007 | 11:16 PM
the_merv's Avatar
And then with a dash of Salt and a little Flour..you have an Engine..
Old Aug 6, 2007 | 11:18 PM
phrozen755's Avatar
ahahaha I was waiting for this !!
Old Aug 6, 2007 | 11:26 PM
the_merv's Avatar
I built a whole damn Engine in my Kitchen..didn't cook anything on it though..
alconk's Avatar
Yep, I toasted a engine from that once so that's why it's a good investment to have the right tools. Sorry to hear about that dude! Good luck!
Old Aug 7, 2007 | 01:29 AM
Red96TA's Avatar
Throwing in some oil adds a nice touch. Vegetable oil that is..... :-)
Old Aug 7, 2007 | 01:32 AM
the_merv's Avatar
We got the Cooking channel in here..
Old Aug 7, 2007 | 01:45 AM
ZONES89RS's Avatar
In-Zane Moderator
Hell, i use a rubber mallet...till i can get the crank bolt started.
Old Aug 7, 2007 | 04:49 AM
smoknta's Avatar
You should never use the crank bolt to pull it on either. Thats a good way to rip out the crank threads, then your really screwed. Just buy an installer.
Old Aug 7, 2007 | 09:55 AM
ZONES89RS's Avatar
In-Zane Moderator
**** that. As long as i catch 4 or more threads i have never had a problem, i have only been doing it for 8 or 9 years, but i have never ripped out the threads, so if it happens i will curse you, straight to hell!!!
Old Aug 7, 2007 | 10:21 AM
dhdenney's Avatar
Installation is probably just preference as I have done that before too. Not the best way I agree, but doable.
Old Aug 7, 2007 | 10:23 AM
1luckeyt/a's Avatar
I always keep my engines in the kitchen, right where my wife likes them
Old Aug 7, 2007 | 10:36 AM
well...ima go down into the garage and take the thing off to make sure i didnt screw my crank up...everything should be good though ill let yall know!
