PTV clearance??
btw if your pistons are +.010 out of the hole and you try to use a .029" gasket you're gonna have worse problems than ptv clearance. because you'll be running a quench of .019" and the pistons will hit the heads. the tightest i have ever run was about .030" and it was a drag race only piece but you really have to watch piston rock etc etc etc to run it that tight and its certainly not for applications that will see any substantial use. also the power difference between .030" and the .045" quench i was running before was exactly dick. car ran and mph the same as the season before.
Frankly though I would be upset the block was cut that far, unless you told them too.
Check the PTV, that is the ONLY way you will know.
Good luck, Ed
, but was curious as to what the norm was for milling a stock set. Being that he is running the same heads, figured he might know. I run a 550 lift cam and had to use commetic .055 gaskets to get the clearance I needed. (Block and heads also needed to be properly surfaced for them to seal! ). I wanted a min. of .100 clearance on the intake and ended up just under that.
That doesn't mean your engine is identical to mine, just means you really need to check.
Just remember you need to check when the piston is closest to the open valve which may not be TDC. PVC is often closest 3-4 degrees past TDC. Easiest way is to use some moddling clay on the piston, assemble, turn it over, disassembly and mic. the clay. Or use test springs, a degree wheel and a dial indicator.
You will likely need different lenght pushrods and your intake milled so it fits properly and doesn't leak.
JB
