Spark plugs on an Lt1
Old Aug 11, 2007 | 06:55 PM
blackbird94's Avatar
Default Spark plugs on an Lt1
well ive been working on the plugs on my 94 formula and as i am moving on to the pass side there is absolutley no way for me to reach more than 1 plug. Anyone have any suggestions!!!! If i remove the alternator will it give me any chance fome above
Old Aug 11, 2007 | 07:11 PM
96lt1m6's Avatar
removing the alt.is the only way to get #2 plug out, with an aftermarket K-member i have seen people get it from the bottom.
Old Aug 12, 2007 | 02:20 AM
Ntimid8r7's Avatar
and for the rest of them on that side, I had to remove the exhaust on my ex's Z to get them from underneath. Cats and Y.
Old Aug 12, 2007 | 10:26 AM
CRAGER's Avatar
Administrator
Exclamation
You should post this in the LT1 section:
LT1-LT4 Modifications
1993-97 Gen II Small Block V8
Peace,
Craig.
Old Aug 12, 2007 | 10:51 AM
Formula413's Avatar
I can get #8 from the top if I take the alternator off and reach back there from the front of the car, my arm just barely fits between the manifold and the wheel well. Not easy though. I still haven't figured out how to get #2, too much stuff in the way.
Old Aug 12, 2007 | 11:31 AM
C5042081's Avatar
it can be done , hope this helps
http://www.shootmyphoto.com/lt1wires/
Old Aug 12, 2007 | 11:43 AM
1994Z28Lt1's Avatar
this will give you a good excuse to consider getting some LT's headers since it is far FAR easier to do plugs on these cars with longtubes
Old Aug 12, 2007 | 11:56 AM
Cheap Guy's Avatar
First of all, this should probably be posted in the LT1 section and you'll get a lot more responses.
1. You do NOT have to remove your exhaust (if it is stock) to change ANY of the plugs.
2. You SHOULD NOT have to remove the starter unless you have huge hands and arms.
3. All of the passenger side plugs can be reached from the top. You may have to lie on top of the engine to get them, but they can be reached. And yes, go ahead and take the alternator off for the one near it.
4. The plugs really aren't that hard...it's the wires that will give you the trouble, especially routing them through the passenger side/alt bracket/power steering pump. Also, the rearmost wire on the driver's side is a bitch due to the fact that it's routed through a metal shield next to the manifold.
5. Take you time.
Old Aug 20, 2007 | 04:09 AM
Fbodynightmare's Avatar
Default Im getting ready to do this !!
well I almost feel like giving it to an auto shop, but oh well just time I guess
Old Aug 20, 2007 | 06:20 AM
CRAGER's Avatar
Administrator
Moved from the General Maintenance & Repairs section.
Old Aug 20, 2007 | 09:57 AM
nychucky's Avatar
If you have an A/C gauge set and a vacuum pump or a friend with both you can take the compressor out and you have access to all four on that side. That is the way I did mine and I had a lot less problems and had plenty of room. That is the way I will do them in the future if needed. I have pretty big arms and I still had plenty of room with the compressor out. The compressor is really not hard to get in and out. Three front housing bolts, on rear bracket bolt and the line assembly bolt and the thing slides out easily. Take the line assembly out and that makes it really easy to get to the plugs, you can work around it though. Don't forget the belt.
Chuck
Old Aug 20, 2007 | 10:47 AM
transambandit's Avatar
yes remove the alt and you can get to #1
Old Aug 20, 2007 | 11:38 AM
96lt1m6's Avatar
#1 is on the drivers side,you are thinking #2 it sits under the alt.take it off and you can get all the plugs from the top
Old Aug 20, 2007 | 12:11 PM
Default Great news for me
I was wondering with all the different posts weither it could be done with only removing the alternator.
Its not that hard but this is the hardest model to do I dont have to do crap to change them out of any other Camaros (ie 2nd,3rd and 4th LS1 Gens)
Later!
Old Aug 20, 2007 | 03:29 PM
C5042081's Avatar
Later!
I only removed the alternator, loosened the ps pump to get the wires around and under, was a pain but it worked. I did 2,4,6 from top and 8 from the bottom
Old Aug 21, 2007 | 01:11 AM
Bones Z28's Avatar
it's a bitch i know. i did do them tho. I had to do what's known as the "superman" where you lay across the car inorder to get the passenger side.
Get headers it becomes a lot easier after you install LT headers on the car.
Old Aug 21, 2007 | 02:01 AM
S2K's Avatar
S2K
From: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
I did 2, 4, & 6 from the top without removing anything. 2 did suck a bit, but was not as bad as 8 in my opinion. I had to do 8 from underneath, once again without taking anything off. Just be patient.
