cam help
Old Aug 12, 2007 | 08:38 PM
LT1Falcon's Avatar
ok i found them. actually only 34 dollars from scoggin dickey. that does not include retainers, and i was wondering if the stock retainers will work with the LT4 springs or will i need specific ones
Old Aug 13, 2007 | 08:58 AM
rkinney's Avatar
I just bought some replacement Lt4 valvesprings from the dealership I work at for $34. Did not come with retainers or keepers, but I already had them. I got the eintire kit years ago, just replacing the springs due to mileage. I'm not sure if you can use the factory retainers. I use a ZZ4 cam and ran 8.7 at 87 mph with a 2.2 60ft on street tires in a 93 6spd car, and could barely hear the cam. I also run a 1.6/1.52 rocker split to bring the intake lift up a bit. brings lift to 506/516 vs. 474/510.
Old Aug 13, 2007 | 09:00 AM
LT1Falcon's Avatar
ok thanks for the info. anybody else know if i can use factory retainers
