Engine tick?
Old Aug 12, 2007 | 01:40 PM
93BlackZ28's Avatar
Default Engine tick?
I've been hearing a tick under the hood for quite some time now. It seems to be coming from inside the drivers side valve cover. So im thinking maybe loose rocker? i really dont know. Is it easy to just pop off the valve covers and tighten and put them back on? Do i need a new gasket? The car only has 62k on it also. Anyone please put in there 2cents. THanks
Old Aug 12, 2007 | 02:04 PM
BsGreenZ's Avatar
valve covers have ruber gaskets so you'll be ok..
Old Aug 12, 2007 | 02:30 PM
blk97z28's Avatar
Humm sometimes I can hear a tick, but i had it checked and it was found out not even to be a problem. Lt1's are well-knowen for being noisy, is it way loud or just like a small tick..tick..tick sound? Devin
Old Aug 21, 2007 | 11:58 PM
93blcZ28's Avatar
thanks for ypur advice devin
Old Aug 22, 2007 | 03:07 AM
Ralls's Avatar
LT1s are sewing machines.
If it's an uneven tick, then it could be one loose rocker arm. I would check for any leaks at the header flange and/or a intake gasket leak.
Old Aug 22, 2007 | 11:26 PM
donkey mule's Avatar
I agree, Whenever I get the tick I tighten the headers down a little and it usually goes away.
