2.5" or 3"
Old Aug 12, 2007 | 08:10 PM
transamws6_97's Avatar
Default 2.5" or 3"
Okay so I'm researching everything I'm gonna need for my true duals but I'm not sure what size pipe to go with? Should I get 3" pipe or 2.5"? For now I'm stock but once I'm out of college most likely I'll get a 383 h/c rebuild. So what do you all think 2.5 or 3
Old Aug 12, 2007 | 08:32 PM
LT1Falcon's Avatar
i was told 2 and a quarter was more than enough for our motors if they are stock so thats what i went with. its probably not gonna make much of a difference as far as performance, but you might notice a sound difference
Old Aug 12, 2007 | 08:54 PM
87lt1rx7's Avatar
I am no expert but i have much experience with small blocks and have found 3" is preffered if going with big h/c setup. 2.5 is good though. 2.25 would work but if you plan on building the engine up later, do the exhaust once and do it right
Old Aug 12, 2007 | 09:09 PM
camar0corey's Avatar
Isn't that the truth, I'm about to change my exhaust for the 3rd time.
I've heard dual 2.5" is plenty flowing, that is would be comparable to a single 4".
Old Aug 12, 2007 | 09:12 PM
96lt1m6's Avatar
i have 2.5" true duals with an x-pipe and a stock motor and i lost some bottom-end but its all good,sounds awesome!
i wont be stock for much longer.
Old Aug 12, 2007 | 09:19 PM
LittleRedZ's Avatar
true dual not single, a single 3" is good up to 450 so lets hope youre making more then that with h/c
LittleRedZ's Avatar
all motor i woulndt go no more then 2.5 duals. I run 3" on mine
Old Aug 13, 2007 | 12:40 AM
socal's Avatar
2.5" bassanie cat back for ls1 f-body modified to fit 92z w ls2
http://www.bassani.com/auto_search/
http://www.bassani.com/part/5798RS5
click pic for better veiw
Old Aug 13, 2007 | 12:42 AM
the_merv's Avatar
Veteran: Air Force
I have a big Cam 402 Stroker, and I plan on goin 3" off the Headers Y'd into 4", then back. I don't have the the room for Duals, otherwise I would go dual 3".
Old Aug 13, 2007 | 07:28 AM
LittleRedZ's Avatar
i'm sorrry but that just looks hideous, and thats coming from somone that does exhaust for a living.
Old Aug 13, 2007 | 07:29 AM
LittleRedZ's Avatar
you can run dual 3" then 2 mufflers and 2 dumps right before the rear axle. I ran the same system you describe, you have to have 450rwhp+ to be able to need that much exhaust, good luck.
Old Aug 13, 2007 | 08:50 AM
LT1MAN's Avatar
dual 3", non-bullet mufflers (hate bullets), over the axle all the way out the back, love the note. no raspy ****, no tips, all black.
Old Aug 13, 2007 | 10:38 AM
LittleRedZ's Avatar
