Went to the track on Friday
First run with the Nittos at 20psi was a 12.7@113 with a spinning 1st gear that was short shifted and a 2.1 60ft...
2nd run I dropped the tires to 14psi, blew out a header gasket on the burn out but still bogged and ran a 12.9@113 with a 2.1 60ft...
So I'm going to get some locking header bolts and then what kind of header gaskets are most of you guys running?
Sucks that I only got one real pass in before something broke since I can't drive for 28 more days... But I thought the mph was pretty good for the weather that night. I think it has low 12s to 12 flat in it on these tires if I can get a track night without anything breaking to get the launch correct.
Yeah I know I need some real tires just don't have the money at the moment...
were at sealevel but here in dallas its been 100 plus everyday....my cam only car trapped 113 in this weather but its a little lighter...if the temp was in the 70's hed prolly be in the 118 range....(find a da calculator and transfer your times to 000 DA
seems most people with sticks don't have as good of luck with nittos so you might check into bfg or m/t radials
I'm rather partial to MT ET Drag Radials.
You'll find a lot of cars here running them and pulling great 60' times.
As for gaskets, I like Percy's dead-soft gaskets with 1" Stage 8 locking bolts.
I've reused them on two different set of headers now without any leaks and I've never had to retighten.
Some people swear by Felpro and standard bolts. I didn't have much luck that way
and to be quite honest, I don't want to have to retighten my header bolts over and
over again but that's just me.
I'm not sure which gaskets I'll run yet but definitely getting some stage 8 locking header bolts so this crap doesn't happen again.
as far as the NITTO's my friends '89TTA runs them with BMR tq arm and BMR lca's,3500 vig.,transbrake, john craig turbo 67mm
1.47 60'
10.77 @128
yes, the car does spin a little and still pulls the wheels and cut 1.46 60' times
so i would say the NITTO's work well!
1.47 60'
10.77 @128
I ordered some stage 8 locking header bolts, going to pick up a set of oem exhaust gaskets since I've blown out 3-4 sets of Felpros, Mr Gasket and Perceys all together since I've had the headers. Then once I burn up these Nittos I'll most likely grab some MT street radials since they make them in 315/35/17 now.
But I still need to run on some et drags if I really want to see what times it is capable of
